Datasheet Texas Instruments TPS57160ZQDGQRQ1 — Даташит
СерияTPS57160-Q1
МодельTPS57160ZQDGQRQ1
Автомобильный понижающий преобразователь 3,5–60 В, 1,5 А с Eco-Mode™ 10-MSOP-PowerPAD от -40 до 125
TPS57160-Q1 1.5-A 60-V Step-Down DC-DC Converter With Eco-modeв„ў Control datasheet
PDF, 2.2 Мб, Версия: E, Файл опубликован: 19 мар 2015
Pin10
Package TypeDGQ
Industry STD TermHVSSOP
JEDEC CodeS-PDSO-G
Package QTY2500
Маркировка5716Z
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Pitch (мм).5
Max Height (мм)1.1
Control ModeCurrent Mode
Duty Cycle(Max)100 %
Iout(Max)1.5 A
Iq(Typ)0.116 мА
Package GroupMSOP-PowerPAD
RatingAutomotive
Regulated Outputs1
Special FeaturesEnable,Frequency Synchronization,Light Load Efficiency,Power Good,Tracking,UVLO Adjustable
Switching Frequency(Max)2500 kHz
Switching Frequency(Min)100 kHz
ТипConverter
Vin(Max)60 В
Vin(Min)3.5 В
Vout(Max)58 В
Vout(Min)0.8 В
  • Evaluation Modules & Boards: TPS57160-Q1EVM
    TPS57160-Q1EVM: EMC Optimized EVM featuring the TPS57160-Q1 Step-down DC/DC Converter
  • Evaluation Modules & Boards: TPS92662EVM6-900
    TPS92662-Q1 Six Channel Matrix Evaluation Module
  • TPS54xxx-Q1 and TPS57xxx-Q1 Devices EMC Performance Comparison Study
    PDF, 8.6 Мб, Файл опубликован: 17 ноя 2015
    This application report provides the Electromagnetic Compatibility (EMC) performance comparison forradiated and conducted emissions between devices in the same high-frequency buck converter family.TPS54xx0-Q1 and TPS57xx0-Q1 devices have few differences in electrical parameters as listed inTable 2. These electrical parametric changes are achieved by implementing minor changes in metallayer
  • Passing CISPR25 Radiated Emissions Using the TPS54160-Q1
    PDF, 857 Кб, Файл опубликован: 4 дек 2013
    This application report provides a summary of CISPR25-Radiated Emissions test results using the TPS54160-Q1 high-frequency buck converter. Similar results can be achieved using other devices in this family. This family of buck converters is capable of passing CISPR25 and other automotive electromagnetic-compatibility (EMC) test specifications. The TPS54160 family of devices does not require the us
  • TPS54xx0-Q1 and TPS57xx0-Q1 Pin Open and Short Test Results (Rev. B)
    PDF, 39 Кб, Версия: B, Файл опубликован: 3 ноя 2015
    This application note provides Pin Open and Short Test Results for the device pins of the TPS54xx0-Q1and TPS57xx0-Q1 family of step-down SWIFTв„ў DC-DC converters. The TPS54xx0-Q1 and TPS57xx0-Q1 family of power devices consists of high-input-voltage step-down regulators that provide a variety ofcurrent options.
  • Interfacing TPS57xxx-Q1 and TPS65320-Q1 Family Devices With Low Impendence Exter
    PDF, 624 Кб, Файл опубликован: 8 дек 2015
  • Design Considerations for DC-DC Converters in Fast-Input Slew Rate Applications
    PDF, 191 Кб, Файл опубликован: 5 мар 2015
    This application report describes the ways to optimize the design of DC-DC converters (TPS54040-Q1, TPS54060-Q1, TPS54140-Q1, TPS54160-Q1, TPS54240-Q1, TPS54260-Q1, TPS57040-Q1, TPS57060-Q1, TPS57140-Q1, and TPS57160-Q1) in applications with fast transition at the input voltage on the rising and falling edges. First, the issues faced under such a scenario are analyzed. Then, design considerations
Серия: TPS57160-Q1 (3)
На английском языке: Datasheet Texas Instruments TPS57160ZQDGQRQ1
