Datasheet Texas Instruments LM3644TTYFFR — Даташит
СерияLM3644
МодельLM3644TTYFFR
Драйвер светодиодной вспышки для камеры с источником тока 1,5 А, 12-DSBGA -40–85
LM3644 Dual 1.5-A Current Source Camera Flash LED Driver datasheet
PDF, 1.5 Мб, Версия: E, Файл опубликован: 8 сен 2016
41 предложений от 16 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Устройства управления светодиодами
727GS
LM3644TTYFFR
от 13 ₽
LM3644TTYFFR
23 ₽
LM3644TTYFFR
68 ₽
Зенер
Россия и страны ТС
LM3644TTYFFR
от 73 ₽
Pin12
Package TypeYFF
Industry STD TermDSBGA
JEDEC CodeR-XBGA-N
Package QTY3000
Маркировка3644TT
Width (мм)1.16
Length (мм)2
Thickness (мм)1.6
Pitch (мм).4
Max Height (мм).625
Iout(Max)2.5 A
Iq(Typ)0.3 мА
LED2
Package GroupDSBGA
Special FeaturesI2C Control,LED Thermal Monitor,OVP,Over Current Protection,Synchronous Rectification
Vin(Max)5.5 В
Vin(Min)2.5 В
  • Evaluation Modules & Boards: LM3644EVM
    Synchronous Boost Dual LED Flash Driver Evaluation Module W/ 1.5A High-Side Current Sources
  • Using the LM3643/4/8 in an Inductorless and/or Simplified PCB Routing Configurat
    PDF, 216 Кб, Файл опубликован: 11 окт 2016
    The LM3643, LM3644 and LM3648 are a family of high power LED flash drivers that can be used as alighting source in many applications ranging from a mobile phones front facing selfie flash to a flash lighton a handheld point of sale (POS) terminal. While each device is highly configurable, there are timeswhere the full feature set might not be needed or where the fine pitch of the device (0
  • Using Flash LED Drivers for Infrared (IR) LED Applications
    PDF, 163 Кб, Файл опубликован: 20 мар 2017
    The LM3643/4/8 devices are commonly used for mobile phone flash LED drivers. This application notediscusses the general applications of IR in mobile devices as well as the behavior of TI’s LM364X devicesfor such applications.These LED flash drivers are small solutions that provide a maximum of 1.5 A to one or two LEDs in eitherpass mode, where the current sources are connected to the input
  • LED Flash-Protection Features
    PDF, 33 Кб, Файл опубликован: 23 авг 2017
    Modern LED camera flash drivers are feature-rich and power dense. Capable of delivering over 2 A ofcurrent to dual LEDs in packages as small as 1.69 mm Г— 1.31 mm, flash LED drivers require built-in safetyand protection features to maintain long-term device and system health. Devices such as the LM3643,LM3644, LM3648, LM3646, LM3642, LM36010, and LM36011 all provide many specific protection
Серия: LM3644 (2)
  • Semiconductors > Power Management > LED Driver > Strobe & Flash LED Driver
На английском языке: Datasheet Texas Instruments LM3644TTYFFR
