Datasheet ТI ADS7844EG4 — Даташит
| Серия | ADS7844 |
| Модель | ADS7844EG4 |
12-битный 8-канальный аналого-цифровой преобразователь с дискретизацией последовательного вывода 20-SSOP
ADS7844: 12-Bit, 8-Channel Serial Output Sampling Analog-To-Digital Converter datasheet
PDF, 750 Кб, Версия: A, Файл опубликован: 17 окт 2003
- Using the ADS7841 and ADS7844 with 15-Clock CyclesPDF, 188 Кб, Файл опубликован: 30 июн 2005
This application report presents an analysis on the use of the 15-clock cycle method of operation for the ADS7841 and ADS7844 described in their respective data sheets. The advent of commercially available processors such as the TMS470 no longer restricts users from implementing the 15-clock method with simple microprocessors. This method, however, does present some challenges to the software inte - Apply TI TSC for Various and Multiple FunctionsPDF, 316 Кб, Файл опубликован: 11 дек 2006
This application report presents several examples showing how a touch screen controller (TSC) from Texas Instruments provides a variety of functions such as graphs, scroll bars, pressure buttons, and analog dials. A simple resistive TSC can be used to achieve all of these functions as long as they are not activated simultaneously. This application report demonstrates a few simple examples how th - Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different - Determining Minimum Acquisition Times for SAR ADCs, part 2PDF, 215 Кб, Файл опубликован: 17 мар 2011
The input structure circuit of a successive-approximation register analog-to-digital converter (SAR ADC) incombination with the driving circuit forms a transfer function that can be used to determine minimum acquisition times for different types of applied input signals. This application report, which builds on Determining Minimum Acquisition Times for SAR ADCs When a Step Function is Applied to - Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference. - Principles of Data Acquisition and Conversion (Rev. A)PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS7844 (16)
