Datasheet Texas Instruments SN74ALVTH162245VR — Даташит
| Серия | SN74ALVTH162245 |
| Модель | SN74ALVTH162245VR |
16-битные шинные трансиверы 2,5 В/3,3 В с выходами с 3 состояниями 48-TVSOP от -40 до 85
2.5-V/3.3-V 16-Bit Bus Transceivers With 3-State Outputs datasheet
PDF, 425 Кб, Версия: A, Файл опубликован: 1 апр 2002
Купить SN74ALVTH162245VR на РадиоЛоцман.Цены — от 21 до 146 ₽14 предложений от 14 поставщиков IC TXRX NON-INVERT 3.6V 48TVSOP. Transceiver, Non-Inverting 2 Element 8 Bit per Element 3-State Output 48-TVSOP. Logic - Buffers, Drivers, Receivers,... | |||
| SN74ALVTH162245VR Texas Instruments | 50 ₽ | ||
| SN74ALVTH162245VR Rochester Electronics | 58 ₽ | ||
| SN74ALVTH162245VR Texas Instruments | 60 ₽ | ||
| SN74ALVTH162245VR Texas Instruments | 146 ₽ | ||
| Pin | 48 |
| Package Type | DGV |
| Industry STD Term | TVSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | VT2245 |
| Width (мм) | 4.4 |
| Length (мм) | 9.7 |
| Thickness (мм) | 1.05 |
| Pitch (мм) | .4 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Bits | 16 |
| F @ Nom Voltage(Max) | 25 Mhz |
| ICC @ Nom Voltage(Max) | 5 мА |
| Output Drive (IOL/IOH)(Max) | -32/64 мА |
| Package Group | TVSOP |
| Package Size: mm2:W x L | 48TVSOP: 62 mm2: 6.4 x 9.7(TVSOP) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | ALVT |
| VCC(Max) | 3.6 В |
| VCC(Min) | 2.3 В |
| Voltage(Nom) | 2.5,3.3 В |
| tpd @ Nom Voltage(Max) | 3.6,3.1 нс |
- Advanced Low-Voltage TechnologyPDF, 59 Кб, Файл опубликован: 27 июл 1999
ALVT, the advanced low-voltage logic family, offers high-performance BiCMOS devices that are functional at 3.3-V and 2.5-V V sub CC and have low propagation delay, low static-power consumption, and 64 mA current drive. Other features include 5-V tolerance; auto3-state; bus hold; partial power down, hot insertion, and live insertion; and excellent simultaneous-switching and output-skew performance. - Bus-Hold CircuitPDF, 418 Кб, Файл опубликован: 5 фев 2001
When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of - 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
TI?s 56-ball MicroStar Jr.E package registered under JEDEC MO-225 has demonstrated through modeling and experimentation that it is an optimal solution for reducing inductance and capacitance improving thermal performance and minimizing board area usage in integrated bus functions. Multiple functions released in the 56-ball MicroStar Jr.E package have superior performance characteristics compa - Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families - Power-Up 3-State (PU3S) Circuits in TI Standard Logic DevicesPDF, 209 Кб, Файл опубликован: 10 май 2002
Серия: SN74ALVTH162245 (5)
- 74ALVTH162245LRG4 SN74ALVTH162245DL SN74ALVTH162245GR SN74ALVTH162245LR SN74ALVTH162245VR
- Semiconductors > Logic > Buffer/Driver/Transceiver > Standard Transceiver
