Datasheet Texas Instruments LM27CIM5X-ZHJ/NOPB — Даташит
СерияLM27
МодельLM27CIM5X-ZHJ/NOPB
Temperature Switch with Fixed Trip Points, 120В°C-150В°C 5-SOT-23
LM27 SOT-23 Accurate, 120C-150C Factory Preset Thermostat datasheet
PDF, 1.0 Мб, Версия: D, Файл опубликован: 30 июл 2013
Pin5
Package TypeDBV
Industry STD TermSOT-23
Package QTY3000
МаркировкаTZHJ
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
# Comparators1
Accuracy Over Temp Range(Max)(C)3
Approx. Price (US$)0.60 | 1ku
InterfaceAnalog Output
Switch
Operating Temperature Range(C)-40 to 85
120 to 150
Тип выходаOpen Drain
Push Pull
Package GroupSOT-23
Package Size: mm2:W x L (PKG)5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23)
Sensor Gain(mV/Deg C)-10.82
SetPoint TypeFactory Programmed
SetPoint Value(deg C)Range (120 to 150)
120
130
140
Special FeaturesHysteresis (2В°C or 10В°C)
Pin-Selectable Hysteresis
Temperature Sensor and Switch
Supply Current(Typ)(uA)40
Supply Voltage(Max)(V)5.5
Supply Voltage(Min)(V)2.7
  • Evaluation Modules & Boards: DIP-ADAPTER-EVM
    DIP Adapter Evaluation Module
  • Semiconductors > Sensing Products > Temperature Sensors > Temperature Switches / Thermostats
LM27CIM5XZHJ/NOPB, LM27CIM5X ZHJ/NOPB
На английском языке: Datasheet Texas Instruments LM27CIM5X-ZHJ/NOPB
