Datasheet Texas Instruments LM77CIMX-3 — Даташит
СерияLM77
МодельLM77CIMX-3
В±1.5В°C Temperature Sensor with Alert Function and I2C/SMBus Interface 8-SOIC -55 to 125
9Bit + Dig Temp Sens & Thermal Window Comparator w/Two-Wire Interface datasheet
PDF, 1.4 Мб, Версия: F, Файл опубликован: 22 мар 2013
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
МаркировкаLM77CIM-3
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Рекомендуемая замена
ReplacementLM77CIMX-3/NOPB
Replacement CodeS
Addresses4
Approx. Price (US$)0.90 | 1ku
InterfaceI2C
SMBus
2-Wire
Iq(Typ)(uA)250
Local Sensor Accuracy(Max)(+/- C)1.5
Operating Temperature Range(C)-55 to 125
Package Size: mm2:W x L (PKG)8SOIC: 29 mm2: 6 x 4.9(SOIC)
Special FeaturesFault Queue
Supply Current(Max)(uA)500
Supply Current(Typ)(uA)250
Supply Voltage(Max)(V)5.5
Supply Voltage(Min)(V)3
Temp Resolution(Max)(bits)10
RoHSTBD
  • Applying I2C-Compatible Temperature Sensors in Systems With Slow Clock Edges (Rev. A)
    PDF, 33 Кб, Версия: A, Файл опубликован: 6 май 2013
    This Application Note describes a method of interfacing a given microcontroller with a Texas Instruments digital temperature sensor.
  • Sensing and Monitoring for Control and Protection Seminar
    PDF, 245 Кб, Файл опубликован: 17 фев 2003
  • Semiconductors > Sensing Products > Temperature Sensors > Local Digital Temperature Sensors
LM77CIMX3, LM77CIMX 3
На английском языке: Datasheet Texas Instruments LM77CIMX-3
