Datasheet Texas Instruments TLC5947DAPRG4 — Даташит
СерияTLC5947
МодельTLC5947DAPRG4
24-канальный 12-битный светодиодный драйвер ШИМ с внутренним генератором 32-HTSSOP от -40 до 85
TLC5947 24-Channel, 12-Bit PWM LED Driver With Internal Oscillator datasheet
PDF, 1.5 Мб, Версия: B, Файл опубликован: 14 янв 2015
Pin32
Package TypeDAP
Industry STD TermHTSSOP
Package QTY2000
МаркировкаTLC5947
Width (мм)6.2
Length (мм)11
Thickness (мм)1.15
Max Height (мм)1.2
Ch to Ch Accuracy(Typ)2 +/- %
Data Transfer Rate(Typ)30 МГц
Package GroupHTSSOP
Package Size: mm2:W x L32HTSSOP: 89 mm2: 8.1 x 11(HTSSOP) PKG
Special FeaturesInternal GS Clock,Thermal Shutdown
  • Hardware Design Considerations for a Wireless LED based Display Design
    PDF, 682 Кб, Файл опубликован: 11 июн 2014
    Scoreboards have different purposes with various features. Scoreboards are typically used for displaying scores of a game played between two teams. These games can be a timed or an untimed event. The application described in this application report creates a multi-sport scoreboard that is cost efficient, portable, and easy to use. The display values on the scoreboard are transmitted wirelessly.
  • Semiconductors > Power Management > LED Driver > Signage & Large Display LED Driver
На английском языке: Datasheet Texas Instruments TLC5947DAPRG4
