Datasheet Texas Instruments TPS65235RUKT — Даташит
СерияTPS65235
МодельTPS65235RUKT
Регулятор напряжения LNB с интерфейсом I2C 20-WQFN от -40 до 85
TPS65235 LNB Voltage Regulator With I2C Interface datasheet
PDF, 2.4 Мб, Версия: A, Файл опубликован: 5 дек 2017
Pin20
Package TypeRUK
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
Width (мм)3
Length (мм)3
Thickness (мм)0.75
Pitch (мм)0.4
Max Height (мм)0.8
Duty Cycle(Max)100 %
Основные особенностиAdjustable Current Limit,I2C,Power Good
Iout(Max)0.65 A
Iq(Typ)0.12 мА
Package GroupWQFN
Regulated Outputs1
Switch Current Limit(Typ)2.8 A
Switching Frequency(Max)1134 kHz
Switching Frequency(Min)977 kHz
ТипConverter
Vin(Max)20 В
Vin(Min)4.5 В
Vout(Max)20 В
Vout(Min)4.5 В
  • Evaluation Modules & Boards: TPS65235EVM-747
    TPS65235 LNB Voltage Regulator with I2C Interface Evaluation Module for DisEqC1.x
  • Evaluation Modules & Boards: TPS65235EVM-694
    TPS65235 LNB Voltage Regulator with I2C Interface Evaluation Module for DisEqC2.x
  • DiSEqC Protocol and LNB Voltage Regulator TPS65235 for Satellite STB/TV
    PDF, 1.3 Мб, Файл опубликован: 14 дек 2016
  • LNB design considerations on TPS65233 TPS65235
    PDF, 1.8 Мб, Файл опубликован: 25 сен 2017
    The TPS65233 and TPS65235 are designed for analog and digital satellite receivers. They are monolithic voltage regulator with I2C interface. This application report mainly introduces some design consideration in application which including inrush current when startup solution to avoid reverse current I2C address and tone mode setup for TPS65233 DisEqc2.x tone design consideration on TP
Серия: TPS65235 (2)
  • Semiconductors > Power Management > DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments TPS65235RUKT
