Datasheet Texas Instruments ADS8328IPWG4 — Даташит
Серия | ADS8328 |
Модель | ADS8328IPWG4 |
2,7–5,5 В, 16 бит, 500 KSPS, последовательный АЦП с мультиплексором 2–1, 16-TSSOP, от –40 до 85
Low Power, 16-Bit, 500-kHz, Single/Dual Unipolar Input, ADC w/Serial I/F datasheet
PDF, 1.8 Мб, Версия: E, Файл опубликован: 27 янв 2011
Pin | 16 | 16 | 16 |
Package Type | PW | PW | PW |
Industry STD Term | TSSOP | TSSOP | TSSOP |
JEDEC Code | R-PDSO-G | R-PDSO-G | R-PDSO-G |
Package QTY | 90 | 90 | 90 |
Carrier | TUBE | TUBE | TUBE |
Маркировка | 8328I A | 8328I | ADS |
Width (мм) | 4.4 | 4.4 | 4.4 |
Length (мм) | 5 | 5 | 5 |
Thickness (мм) | 1 | 1 | 1 |
Pitch (мм) | .65 | .65 | .65 |
Max Height (мм) | 1.2 | 1.2 | 1.2 |
# Input Channels | 2 |
Analog Voltage AVDD(Max) | 5.5 В |
Analog Voltage AVDD(Min) | 2.7 В |
Архитектура | SAR |
Digital Supply(Max) | 5.5 В |
Digital Supply(Min) | 1.65 В |
INL(Max) | 2 +/-LSB |
Input Range(Max) | 5.5 В |
Тип входа | Differential,Single-Ended |
Integrated Features | Daisy-Chainable,Oscillator |
Interface | SPI |
Multi-Channel Configuration | Multiplexed |
Package Group | TSSOP |
Package Size: mm2:W x L | 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG |
Power Consumption(Typ) | 10.6 mW |
Rating | Catalog |
Reference Mode | Ext |
Разрешение | 16 Bits |
SINAD | 91 дБ |
SNR | 91 дБ |
Sample Rate (max) | 500kSPS SPS |
Sample Rate(Max) | 0.5 MSPS |
THD(Typ) | -98 дБ |
- Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different - Determining Minimum Acquisition Times for SAR ADCs, part 2PDF, 215 Кб, Файл опубликован: 17 мар 2011
The input structure circuit of a successive-approximation register analog-to-digital converter (SAR ADC) incombination with the driving circuit forms a transfer function that can be used to determine minimum acquisition times for different types of applied input signals. This application report, which builds on Determining Minimum Acquisition Times for SAR ADCs When a Step Function is Applied to - Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference. - Principles of Data Acquisition and Conversion (Rev. A)PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS8328 (7)
- ADS8328IBPW ADS8328IBPWG4 ADS8328IBRSAT ADS8328IPW ADS8328IPWG4 ADS8328IPWR ADS8328IRSAT
