Datasheet Texas Instruments DDC114IRTCT — Даташит
СерияDDC114
МодельDDC114IRTCT
DDC114: 20-битный аналого-цифровой преобразователь с четырьмя токовыми входами 48-VQFN от -40 до 85
Quad Current Input, 20-Bit Analog-To-Digital Converter datasheet
PDF, 1.0 Мб, Версия: C, Файл опубликован: 1 апр 2009
Pin48
Package TypeRTC
Industry STD TermVQFNP
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаDDC114
Width (мм)7
Length (мм)7
Thickness (мм).9
Pitch (мм).5
Max Height (мм).9
# Input Channels4
InterfaceSPI
Package GroupVQFN
Package Size: mm2:W x L48VQFN: 49 mm2: 7 x 7(VQFN) PKG
Разрешение20 Bits
Sample Rate (max)3.125kSPS SPS
Special FeaturesComputed Tomography (CT)
  • Evaluation Modules & Boards: DDC11XEVM-PDK
    DDC11xEVM-PDK Performance Demonstration Kit
  • Programming Tricks for Higher Conversion Speeds Utilizing Delta Sigma Converters
    PDF, 105 Кб, Файл опубликован: 27 сен 2000
    Delta-Sigma Analog-to-Digital Converters are well known for their innate ability to resolve an analog input signal to very small LSB voltage ranges. The primarily applications for this type of product is in the Industrial Process Control market such as direct transducer interface for pressure, temperature, flow, weigh scales and force measurement systems.
Серия: DDC114 (3)
  • Semiconductors > Sensing Products > Photodiode Sensing
На английском языке: Datasheet Texas Instruments DDC114IRTCT
