Datasheet ТI TLC4541IDGK — Даташит
| Серия | TLC4541 |
| Модель | TLC4541IDGK |
16-разрядный последовательный выход АЦП 200 KSPS, автоматическое PWRDN, несимметричный вход 8-VSSOP от -40 до 85
5-V, Low Power- 16-/14-Bit 100-200 KSPS Serial ADC with Auto-Power Down datasheet
PDF, 1.0 Мб, Файл опубликован: 10 июл 2000
- Interfacing the TLC4541 to TMS320C6711 DSPPDF, 69 Кб, Файл опубликован: 13 сен 2002
This application note presents a method for interfacing the TLC4541 16-bit SAR analog-to-digital converter to the TMS320C6711в„ў DSP McBSP1. The software developed reads 1024 samples continuously from the TLC4541. In an effort to reduce development time, the source code is made available on TI's website. - Interfacing the TLC4541 & the DAC7654 to the MSP430F449PDF, 877 Кб, Файл опубликован: 12 авг 2005
The purpose of this application report is to demonstrate the combination of a serial analog-to-digital converter (ADC) and a serial digital-to-analog converter (DAC) on a development platform. The ADC and the DAC featured are the TLC4541 and the DAC7654, respectively. These devices are presented using the HPA449 as a low-cost development platform. The application report briefly describes each comp - Interfacing Low Power Serial (SPI) ADCs to the MSP430F449PDF, 407 Кб, Файл опубликован: 4 фев 2005
This application report discusses the serial peripheral interface (SPI) implementation of a data acquisition system featuring the following devices: TLV2541, TLC2551, TLC3541, and TLC4541. These analog-to-digital converters (ADC) offer options for users ranging from extremely low power and wide voltage supply range to fast conversion throughput. All devices share a small (MSOP) footprint and are p - Determining Minimum Acquisition Times for SAR ADCs, part 2PDF, 215 Кб, Файл опубликован: 17 мар 2011
Серия: TLC4541 (5)
- TLC4541ID TLC4541IDG4 TLC4541IDGK TLC4541IDGKG4 TLC4541IDGKR
