Datasheet Texas Instruments UCC29412PW — Даташит
СерияUCC29412
МодельUCC29412PW
Синхронный повышающий преобразователь малой мощности 8-TSSOP от -40 до 85
Преобразователь DC/DC, Step-Up Regulator Low Power Synchronous Boost Converter Conv DC-DC 1.3V to 3.2V Step Up Single-Out 3.3V 0.06A 0.2W 8Pin...
UCC29412PW
247 ₽
Эиком
UCC29412PW
от 615 ₽
UCC29412PW
727GS
UCC29412PW
Package TypePW
Industry STD TermTSSOP
Маркировка29412
Width (мм)4.4
Length (мм)3
Thickness (мм)1
Max Height (мм)1.2
RoHSНе совместим
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
Серия: UCC29412 (2)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments UCC29412PW
