Datasheet Texas Instruments CD74HC4046ANSRE4 — Даташит
СерияCD74HC4046A
МодельCD74HC4046ANSRE4
Высокоскоростная КМОП логическая фазовая автоподстройка частоты с ГУН 16-SO от -55 до 125
CD54HC4046A, CD74HC4046A, CD54HCT4046A, CD74HCT4046A datasheet
PDF, 833 Кб, Версия: J, Файл опубликован: 21 ноя 2003
Pin16
Package TypeNS
Industry STD TermSOP
Package QTY2000
МаркировкаHC4046AM
Width (мм)5.3
Length (мм)10.3
Thickness (мм)1.95
Max Height (мм)2
Bits1
F @ Nom Voltage(Max)70 Mhz
ICC @ Nom Voltage(Max)0.08 мА
Output Drive (IOL/IOH)(Max)5.2/-5.2 мА
Package GroupSO
Package Size: mm2:W x L16SO: 80 mm2: 7.8 x 10.2(SO) PKG
Technology FamilyHC
VCC(Max)6 В
VCC(Min)2 В
Voltage(Nom)3.3,5 В
tpd @ Nom Voltage(Max)64 нс
  • Implementation of FSK Modulation and Demodulation using CD74HC4046A
    PDF, 1.3 Мб, Файл опубликован: 25 ноя 2013
  • CMOS Phase-Locked-Loop Applications (Rev. B)
    PDF, 687 Кб, Версия: B, Файл опубликован: 19 сен 2002
    Applications of the HC/HCT4046A phase-locked loop (PLL) and HC/HCT7046A PLL with lock detection are provided including design examples with calculated and measured results. Features of these devices relative to phase comparators lock indicators voltage-controlled oscillators (VCOs) and filter design are presented.
  • Generating Low Phase-Noise Clocks for Audio Data Converters from Low Frequency
    PDF, 860 Кб, Файл опубликован: 31 мар 2008
    Generating a high-frequency system clock Fs (128fs to 768fs) from a low-frequency sampling clock fs (10 kHz to 200 kHz) is challenging, while attempting to maintain low phase jitter. A traditional phase-lock loop (PLL) can do the frequency translation, but the added phase jitter prevents the generated system clock signal from effectively driving high-performance audio data converters. This applica
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
  • Semiconductors > Logic > Specialty Logic > Phase-Locked-Loop (PLL)/Oscillator
На английском языке: Datasheet Texas Instruments CD74HC4046ANSRE4
