Datasheet Texas Instruments LP5900TLX-4.5/NOPB — Даташит
СерияLP5900
МодельLP5900TLX-4.5/NOPB
Сверхмалошумящий LDO 150 мА для радиочастотных и аналоговых цепей не требует байпасного конденсатора 4-DSBGA от -40 до 125
LP5900 150-mA Ultra-Low-Noise LDO for RF and Analog Circuits - Requires No Bypass Capacitor datasheet
PDF, 1.6 Мб, Версия: R, Файл опубликован: 1 июн 2016
Pin4
Package TypeYZR
Industry STD TermDSBGA
JEDEC CodeR-XBGA-N
Package QTY3000
Width (мм)1.3
Length (мм)1.5
Thickness (мм).675
Pitch (мм).5
Max Height (мм).675
Точность3 %
Fixed Output Options1.5,1.575,1.8,1.9, 2, 2.1, 2.2, 2.3, 2.5, 2.6, 2.65, 2.7, 2.75,2.8, 2.85,3.0,3.3,4.5 В
Iout(Max)0.15 A
Iq(Typ)0.025 мА
Noise6.5 uVrms
Output Capacitor TypeCeramic
Output OptionsFixed Output
PSRR @ 100KHz40 дБ
Package GroupDSBGA
Regulated Outputs1
Special FeaturesEnable
Thermal Resistance ОёJA80 В°C/W
Vdo(Typ)80 мВ
Vin(Max)5.5 В
Vin(Min)2.5 В
Vout(Max)4.5 В
Vout(Min)1.5 В
  • Evaluation Modules & Boards: LP5900SD-3.0EV
    Ultra Low Noise, 150mA Linear Regulator for RF Analog Circuits Requires No Bypass Capacitor
  • Evaluation Modules & Boards: LP5900TL-2.2EV
  • Evaluation Modules & Boards: LP5900TL-2.8EV
  • Evaluation Modules & Boards: LP5900SD-2.8EV
  • Evaluation Modules & Boards: LP5900TL-2.5EV
  • Evaluation Modules & Boards: LP5900TL-1.5EV
  • Evaluation Modules & Boards: LP5900TL-2.0EV
  • Evaluation Modules & Boards: LP5900SD-1.8EV
    Ultra Low Noise, 150mA Linear Regulator for RF Analog Circuits Requires No Bypass Capacitor EVM
  • Evaluation Modules & Boards: LP5900SD-2.5EV
  • Evaluation Modules & Boards: LMK61E0MEVM
    LMK61E0M Ultra-Low-Jitter Programmabler Oscillator Evaluation Module
  • Evaluation Modules & Boards: LMK61E2EVM
    LMK61E2EVM Ultra-Low-Jitter Programmable Oscillator Evaluation Module
  • Evaluation Modules & Boards: LP5900TL-3.0EV
  • Evaluation Modules & Boards: LP5900TL-3.3EV
  • Evaluation Modules & Boards: LP5900SD-3.3EV
  • Evaluation Modules & Boards: LP5900TL-1.8EV
  • Evaluation Modules & Boards: LP5900TL-2.6EV
  • AN-2145 Power Considerations for SDI Products (Rev. B)
    PDF, 63 Кб, Версия: B, Файл опубликован: 26 апр 2013
    This application report discusses the issues and trade-offs that VCC ripple has on the performance of SDI components.
  • AN-1950 Silently Powering Low Noise Applications (Rev. A)
    PDF, 10.5 Мб, Версия: A, Файл опубликован: 22 апр 2013
    This application report explains how to implement a low noise switch mode power supply solution. Itintroduces the sources of noise and explain how to minimize them. A big factor in noise generation andpropagation is the printed circuit board layout. Important basics are discussed. Circuit measurementtechniques are also explained to guide a design engineer towards a low noise but efficient so
  • AN-2146 Power Design for SDI and Other Noise-Sensitive Devices (Rev. A)
    PDF, 1.4 Мб, Версия: A, Файл опубликован: 26 апр 2013
    This application report discusses various solutions for meeting the power requirements of serial digital interface (SDI) video components.
LP5900TLX4.5/NOPB, LP5900TLX 4.5/NOPB
На английском языке: Datasheet Texas Instruments LP5900TLX-4.5/NOPB
