Datasheet Texas Instruments LM2742MTCX/NOPB — Даташит
СерияLM2742
МодельLM2742MTCX/NOPB
Синхронный понижающий регулятор напряжения 2,2–16 В с регулируемым плавным пуском 14-TSSOP от -40 до 125
LM2742 N-Chan FET Synch Buck Reg Cntrlr for Low Output Voltages datasheet
PDF, 1.4 Мб, Версия: C, Файл опубликован: 28 мар 2013
Pin1414
Package TypePWPW
Industry STD TermTSSOPTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
МаркировкаMTC2742
Width (мм)4.44.4
Length (мм)55
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Control ModeVoltage Mode
Duty Cycle(Max)90 %
Iout(Max)20 A
Iq(Typ)1.5 мА
Number of Phases1
Package GroupTSSOP
Regulated Outputs1
Special FeaturesEnable,Power Good,Synchronous Rectification
Switching Frequency(Max)2000 kHz
Switching Frequency(Min)50 kHz
ТипController
Vin(Max)16 В
Vin(Min)2.2 В
Vout(Max)13.5 В
Vout(Min)0.6 В
  • Automated Frequency Response Analyzer
    PDF, 939 Кб, Файл опубликован: 9 окт 2013
    This application report discusses a new method of doing stability Analysis testing by using basic labequipment, while not requiring any specific instruments.
  • AN-1603 LM274X Reference Designs (Rev. C)
    PDF, 222 Кб, Версия: C, Файл опубликован: 1 май 2013
    This application note presents several reference designs that implement the LM274X synchronous buckcontroller. The designs address various applications in a wide variety of configurations. The designreference will give an engineer a head start on their project, with designs encompassing sequencing,tracking, synchronizing multiple power supplies, DDR termination, buck-boost, low PCB real esta
  • Current Limit Foldback Improves Short Circuit Protection in LM274X Family (Rev. B)
    PDF, 89 Кб, Версия: B, Файл опубликован: 23 апр 2013
    This application report discusses the function of the low side current limit used in the LM274X, andpresents a simple method to enhance the short-circuit protection. the current limit is required to protect thepower components from thermal stress, which can reduce life span. Typically, high side current limitdesigns require an internal rising edge blanking time or external filter to avoid no
  • Optmiz Pwr Cntrlr Dsigns thru Utiliz Freq & Sync, Ext Ref, Trking & Precis EN
    PDF, 359 Кб, Файл опубликован: 24 апр 2008
  • Reduce buck-converter EMI and voltage stress by minimizing inductive parasitics
    PDF, 926 Кб, Файл опубликован: 21 июл 2016
  • Power Management Considerations for FPGAs and ASICs
    PDF, 745 Кб, Файл опубликован: 22 мар 2007
Серия: LM2742 (2)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Controller (External Switch)
На английском языке: Datasheet Texas Instruments LM2742MTCX/NOPB
