Datasheet Texas Instruments TLC5942PWPG4 — Даташит
СерияTLC5942
МодельTLC5942PWPG4
16-канальный 12-битный ШИМ с 7-битной точечной коррекцией 28-HTSSOP от -40 до 85
16-Channel, 12-Bit PWM LED Driver with 7-Bit Dot Correction datasheet
PDF, 879 Кб, Версия: B, Файл опубликован: 23 окт 2007
Pin28
Package TypePWP
Industry STD TermHTSSOP
Package QTY50
МаркировкаTLC5942
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
Рекомендуемая замена
ReplacementTLC5946PWPG4
Replacement CodeQ
  • Using the TLC5940 with Higher LED Supply Voltages and Series LEDs
    PDF, 353 Кб, Файл опубликован: 20 авг 2007
    This application report describes how to accommodate higher LED supply voltages and increase the number of series LEDs that the TLC5940 can drive.
  • Grayscale and Dot-Corrected LED Display Using TLC5941 (Rev. A)
    PDF, 198 Кб, Версия: A, Файл опубликован: 5 мар 2008
    The TLC5941 LED driver uses a serial data interface to receive grayscale and dot correction data. This application report discusses the hardware and firmware to drive the TLC5941 with a MSP430F427 microcontroller.
  • LED Driver--Paralleled Outputs Provide High Current Outputs
    PDF, 957 Кб, Файл опубликован: 25 сен 2006
    This application report describes how to use the TLC5922, TLC5923, and TLC5924 to drive high-current LEDs. These ICs are designed to provide 16 individually controllable constant-current sinks. However, the 16 outputs can be connected in parallel to increase the current drive capability. Paralleling the outputs of these ICs allows the TLC5922, TLC5923, and TLC5924 to drive high-power LEDs such as
Серия: TLC5942 (2)
  • Semiconductors > Power Management > LED Driver > Signage & Large Display LED Driver
На английском языке: Datasheet Texas Instruments TLC5942PWPG4
