Datasheet Texas Instruments OPA2614IDG4 — Даташит
СерияOPA2614
МодельOPA2614IDG4
Двойной операционный усилитель с высоким коэффициентом усиления, высоким выходным током и ограничением тока 8-SOIC от -40 до 85
Dual, High Gain Bandwidth, High Output Current, Op Amp with Current Limit datasheet
PDF, 722 Кб, Версия: D, Файл опубликован: 28 авг 2008
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY7575
CarrierTUBETUBE
МаркировкаOPA2614
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
2nd Harmonic65 dBc
3rd Harmonic87 dBc
@ MHz1
Acl, min spec gain2 V/V
Additional FeaturesDecompensated
АрхитектураBipolar,Voltage FB
BW @ Acl180 МГц
CMRR(Min)88 дБ
CMRR(Typ)100 дБ
GBW(Typ)290 МГц
Input Bias Current(Max)12000 pA
Iq per channel(Max)6.2 мА
Iq per channel(Typ)6 мА
Количество каналов2
Offset Drift(Typ)3.3 uV/C
Output Current(Typ)350 мА
Rail-to-RailNo
Slew Rate(Typ)145 V/us
Total Supply Voltage(Max)12 +5V=5, +/-5V=10
Total Supply Voltage(Min)5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)1.8 нВ/rtГц
Vn at Flatband(Typ)1.8 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)1 мВ
  • Evaluation Modules & Boards: DEM-OPA268XU
    DEM-OPA268xU: Demonstration Fixture
  • Evaluation Modules & Boards: DEM-OPA-SO-2A
    DEM-OPA-SO-2A
  • Active Output Impedance for ADSL Line Drivers
    PDF, 636 Кб, Файл опубликован: 26 ноя 2002
    Signal termination is very common in bidirectional communication systems. Termination allows for receiving signals while transmitting different signals at the same time. With the increasing popularity of asymmetrical digital subscriber lines (ADSL), the requirement for a low power line driver amplifier combined with line termination becomes a very difficult goal. This application note examines the
  • RLC Filter Design for ADC Interface Applications (Rev. A)
    PDF, 299 Кб, Версия: A, Файл опубликован: 13 май 2015
    As high performance Analog-to-Digital Converters (ADCs) continue to improve in their performance, the last stage interface from the final amplifier into the converter inputs becomes a critical element in the system design if the full converter dynamic range is desired. This application note describes the performance and design equations for a simple passive 2nd-order filter used successfully in AD
  • ADS5500, OPA695: PC Board Layout for Low Distortion High-Speed ADC Drivers
    PDF, 273 Кб, Файл опубликован: 22 апр 2004
    Once an analog-to-digital converter (ADC) and a driver/interface have been selected for a given application, the next step to achieving excellent performance is laying out the printed circuit board (PCB) that will support the application. This application report describes several techniques for optimizing a high-speed, 14-bit performance, differential driver PCB layout using a wideband operation
  • Measuring Board Parasitics in High-Speed Analog Design
    PDF, 134 Кб, Файл опубликован: 7 июл 2003
    Successful circuit designs using high-speed amplifiers can depend upon understanding and identifying parasitic PCB components. Simulating a design while including PCB parasitics can protect against unpleasant production surprises. This application report discusses an easy method for measuring parasitic components in a prototype or final PC board design by using a standard oscilloscope and low freq
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA2614IDG4
