Datasheet Texas Instruments MSP430F67451AIPEU — Даташит
| Серия | MSP430F67451A |
| Модель | MSP430F67451AIPEU |
MSP430F67451A Микроконтроллер смешанных сигналов 128-LQFP от -40 до 85
MSP430F677x1A, MSP430F676x1A, MSP430F674x1A Polyphase Metering SoCs datasheet
PDF, 2.9 Мб, Файл опубликован: 28 май 2014
|  Купить MSP430F67451AIPEU на РадиоЛоцман.Цены — от 253 до 1 520 ₽ 11 предложений от 11 поставщиков IC MCU 16BIT 128KB FLASH 128LQFP. CPUXV2 MSP430F6xx Microcontroller IC 16-Bit 25MHz 128KB (128K x 8) FLASH 128-LQFP (20x14). Embedded -... | |||
| MSP430F67451AIPEU Texas Instruments | 253 ₽ | ||
| MSP430F67451AIPEU Texas Instruments | 582 ₽ | ||
| MSP430F67451AIPEU Texas Instruments | 745 ₽ | ||
| MSP430F67451AIPEU Texas Instruments | по запросу | ||
| Pin | 128 |
| Package Type | PEU |
| Industry STD Term | LQFP |
| JEDEC Code | R-PQFP-G |
| Package QTY | 72 |
| Carrier | JEDEC TRAY (10+1) |
| Маркировка | F67451A |
| Width (мм) | 14 |
| Length (мм) | 20 |
| Thickness (мм) | 1.4 |
| Pitch (мм) | .5 |
| Max Height (мм) | 1.6 |
| Mechanical Data | Скачать |
| ADC | ADC10 - 6ch,SigmaDelta24 - 4ch |
| AES | N/A |
| Active Power | 346.8 uA/MHz |
| Additional Features | LCD,Real-Time Clock,Watchdog,Temp Sensor,Brown Out Reset,IrDA |
| BSL | UART |
| CPU | MSP430 |
| DMA | 3 |
| Featured | f6 |
| Тактовая частота | 25 МГц |
| GPIO Pins | 90 |
| I2C | 2 |
| Max VCC | 3.6 |
| Min VCC | 1.8 |
| Multiplier | 32x32 |
| Non-volatile Memory | 128 KB |
| Package Group | LQFP |
| Package Size: mm2:W x L | 100LQFP: 256 mm2: 16 x 16(LQFP) PKG |
| RAM | 16 KB |
| Rating | Catalog |
| SPI | 6 |
| Special I/O | N/A |
| Standby Power | 2.9 LPM3-uA |
| Timers - 16-bit | 4 |
| UART | 4 |
| Wakeup Time | 5 us |
- Development Kits: MSP-TS430PEU128
 MSP-TS430PEU128 - 128-pin Target Development Board for MSP430F6x MCUs
- Evaluation Modules & Boards: EVM430-F6779
 EVM430-F6779 - 3 Phase Electronic Watt-Hour EVM for Metering
- Development Kits: MSP-FET430U128
 128-pin Target Development Board and MSP-FET Programmer Bundle for MSP430F6x MCUs
- JTAG Emulators/ Analyzers: ENERGYTRACE
 MSP EnergyTrace Technology
- Differences Between MSP430F67xx and MSP430F67xxA DevicesPDF, 3.5 Мб, Файл опубликован: 30 мар 2015
 This application report describes the enhancements of the MSP430F67xxA devices from the non-A MSP430F67xx devices. In the course of this application report, the MSP430F67xx errata that are fixed in the MSP430F67xxA and the additional features added to the MSP430F67xxA devices are discussed. In addition, metrology results are compared to further show that the changes implemented in the MSP430F67xxA
- Designing With MSP430 and Segment LCDs (Rev. A)PDF, 2.1 Мб, Версия: A, Файл опубликован: 20 июл 2015
 Segment liquid crystal displays (LCDs) are needed to provide information to users in a wide variety of applications from smart meters to electronic shelf labels (ESL) to medical equipment. Several MSP430в„ў microcontroller families include built-in low-power LCD driver circuitry that allows the MSP430 MCU to directly control the segmented LCD glass. This application note helps explain how segmented
- General Oversampling of MSP ADCs for Higher Resolution (Rev. A)PDF, 551 Кб, Версия: A, Файл опубликован: 1 апр 2016
 Multiple MSP ultra-low-power microcontrollers offer analog-to-digital converters (ADCs) to convert physical quantities into digital numbers, a function that is widely used across numerous applications. There are times, however, when a customer design demands a higher resolution than the ADC of the selected MSP can offer. This application report, which is based on the previously-published Oversampl
- MSP Code Protection FeaturesPDF, 752 Кб, Файл опубликован: 7 дек 2015
 MSP microcontrollers (MCUs) offer a number of features to help control code accessibility in the device, to add different layers of code access management and protection strategies. These include features that can lock or password protect the JTAG/SBW access, IP Encapsulation (IPE) to isolate sensitive code with different permissions than the rest of the program, and bootloader (BSL) access featur
- ESD Diode Current SpecificationPDF, 520 Кб, Файл опубликован: 7 дек 2015
 This document explains the maximum ESD diode current specified for GPIO on MSP microcontrollers. Sometimes signals on specific pins exceed the supply of the MSP MCU. In such a case, the device can handle this overvoltage condition through the ESD diodes, but the ESD diode specification must be considered during application design. The items to be considered are described in this document.
Серия: MSP430F67451A (4)
- MSP430F67451AIPEU MSP430F67451AIPEUR MSP430F67451AIPZ MSP430F67451AIPZR
- Semiconductors > Microcontrollers (MCU) > MSP430 ultra-low-power MCUs > MSP430F5x/6x
