Клеммники KEEN SIDE
Datasheet Texas Instruments LM3407MY/NOPB — Даташит
СерияLM3407
МодельLM3407MY/NOPB
Плавающий понижающий преобразователь с постоянным выходным током, 350 мА для мощных светодиодов 8-MSOP-PowerPAD от -40 до 125
LM3407 350-mA, Constant Current Output Floating Buck Switching Converter for High-Power LEDs datasheet
PDF, 1.3 Мб, Версия: C, Файл опубликован: 15 ноя 2016
Package TypeDGN
Industry STD TermHVSSOP
JEDEC CodeS-PDSO-G
Package QTY1000
МаркировкаSTZB
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Max Height (мм)1.1
Dimming MethodPWM
Входное напряжениеDC/DC Type
Iout(Max)0.35 A
Iq(Typ)0.78 мА
Package GroupMSOP-PowerPAD
Package Size: mm2:W x L8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) PKG
Power Factor CorrectionN/A Min
Regulated Outputs1
Special FeaturesAdjustable Switch Frequency,Enable/Shutdown,Integrated Switch,Thermal Shutdown
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)300 kHz
TopologyBuck
ТипConverter,Inductive
Vin(Max)30 В
Vin(Min)4.5 В
Vout(Max)27 В
Vout(Min)0.45 В
Vref0.2 В
  • Evaluation Modules & Boards: LM3407EVAL
    350mA, Constant Current Output Floating Buck Switching Regulator Evaluation Board
  • AN-1982 Small, Wide Input Voltage Range LM2842 Keeps LEDs Cool (Rev. A)
    PDF, 60 Кб, Версия: A, Файл опубликован: 23 апр 2013
    The world seems to be poised to make the leap to LED lighting. Incandescent has been deemed tooinefficient, which it is, and fluorescent lighting often does not achieve the lifetime it claims. Fluorescentalso has another set of baggage, dangerous chemicals. So the logical choice that most people believe cantake the crown is high brightness (HB) LEDs. HBLEDs are becoming more attractive as th
  • AN-1656 Design Challenges of Switching LED Drivers (Rev. A)
    PDF, 171 Кб, Версия: A, Файл опубликован: 3 май 2013
    Using a switching regulator as an LED driver requires the designer to convert a voltage regulator into acurrent regulator. Beyond the challenge of changing the feedback system to control current, the LEDsthemselves present a load characteristic that is much different than the digital devices and other loads thatrequire constant voltage. The LED WEBENCHВ® online design environment predicts and
Серия: LM3407 (2)
  • Semiconductors > Power Management > LED Driver > Illumination & General Lighting LED Driver
На английском языке: Datasheet Texas Instruments LM3407MY/NOPB
