Datasheet Texas Instruments ADS1230IPWG4 — Даташит
СерияADS1230
МодельADS1230IPWG4
20-битный дельта-сигма АЦП для мостовых датчиков 16-TSSOP от -40 до 85
20-Bit Analog-to-Digital Converter for Bridge Sensors datasheet
PDF, 1.1 Мб, Версия: B, Файл опубликован: 5 сен 2012
IC ADC 20BIT SIGMA-DELTA 16TSSOP. 20 Bit Analog to Digital Converter 1 Input 1 Sigma-Delta 16-TSSOP. Data Acquisition - Analog to...
Рутоника
ADS1230IPWG4
504 ₽
ADS1230IPWG4
ADS1230IPWG4
ADS1230IPWG4
Pin16
Package TypePW
Industry STD TermTSSOP
Package QTY90
МаркировкаADS1230
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
# Input Channels1
Analog Voltage AVDD(Max)5.3 В
Analog Voltage AVDD(Min)2.7 В
АрхитектураDelta-Sigma
Digital Supply(Max)5.3 В
Digital Supply(Min)2.7 В
INL(Max)6.29 +/-LSB
Input Range(Max)0.039 В
Тип входаDifferential,Single-Ended
Integrated Features50/60 Hz Rejection,Oscillator,PGA
InterfaceSPI
Multi-Channel ConfigurationN/A
Package GroupTSSOP
Package Size: mm2:W x L16TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG
Power Consumption(Typ)2.9 mW
Reference ModeExt
Разрешение20 Bits
Sample Rate (max)80SPS SPS
Sample Rate(Max)0.00008 MSPS
  • Delta-Sigma ADC Design for Bridge Sensor Applications
    PDF, 98 Кб, Файл опубликован: 30 сен 2011
    This application report reviews several different types of bridge sensors, including characteristics of each type, and discusses the key parameters of delta-sigma (О”ОЈ) analog-to-digital converters (ADCs) at the system level. Additionally, the parameters of a О”ОЈ ADC are considered for use in common bridge sensor applications
  • Digital Filter Types in Delta-Sigma ADCs
    PDF, 219 Кб, Файл опубликован: 27 июн 2017
    This application report discusses digital filters which are a ubiquitous feature in delta-sigma analog todigital converters (ADCs). Digital low-pass filters are essential to the functionality of a delta-sigma ADCwhich relies on oversampling and noise shaping to push quantization noise out of band. There arevariations between the types of digital filters used in delta-sigma ADCs that provide
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
На английском языке: Datasheet Texas Instruments ADS1230IPWG4
