Datasheet Texas Instruments 66AK2L06XCMSA2 — Даташит
Серия66AK2L06
Модель66AK2L06XCMSA2
Многоядерная однокристальная система DSP+ARM KeyStone II (SoC) 900-FCBGA от -40 до 100
66AK2L06 Multicore DSP+ARM KeyStone II System-on-Chip (SoC) datasheet
PDF, 1.9 Мб, Файл опубликован: 21 апр 2015
Pin900900900
Package TypeCMSCMSCMS
Package QTY444444
Маркировка@2013A1.2GHZ66AK2L06XCMS
Width (мм)252525
Length (мм)252525
Thickness (мм)2.982.982.98
ARM CPU2 ARM Cortex-A15
ARM MHz1200 Max.
ApplicationsAvionics and Defense,Medical,Test and Measurement
DRAMDDR3,DDR3L
DSP4 C66x
DSP MHz1200 Max.
EMAC4-port 1Gb Switch
Hardware AcceleratorsFFT Coprocessor,Digital Front End
I2C3
JESD204B4 Lanes
On-Chip L2 Cache1024 KB (ARM Cluster),1024 KB (per C66x DSP core)
Operating SystemsIntegrity,Linux,SYS/BIOS,VxWorks
Рабочий диапазон температурот -40 до 100,0 до 100 C
Other On-Chip Memory3072 KB
PCI/PCIe2 PCIe Gen2
SPI3
UART4 SCI
USB1
  • Evaluation Modules & Boards: XEVMK2LX
    66AK2L06 Evaluation Module
  • JTAG Emulators/ Analyzers: TMDSEMU560V2STM-U
    XDS200 USB Debug Probe
  • TPS544Bxx/TPS544Cxx Powering TCI6630K2L in Smart Reflex Class 0 TC Mode
    PDF, 154 Кб, Файл опубликован: 18 сен 2015
    This application report describes an application circuit example of the TPS544B/Cxx family of power management IC (PMIC) powering the Smart-Reflex digital core supply of the TCI6630K2L SoC. Smart-Reflex Class 0 Temperature Compensation (Class 0 TC) mode of operation of the TCI6630K2L device is emphasized. Assumption is that temperature compensation mode is enabled using the function provided in th
  • 66AK2L06 JESD Attach to ADC12J4000/DAC38J84 Getting Started Guide (Rev. B)
    PDF, 8.8 Мб, Версия: B, Файл опубликован: 20 июн 2016
  • Keystone EDMA FAQ
    PDF, 1.3 Мб, Файл опубликован: 1 сен 2016
    This document is a collection of frequently asked questions (FAQs) on enhanced direct memory access (EDMA) on KeyStoneв„ў I (KS1) and KeyStone II (KS2) devices, along with useful collateral and software reference links.
  • System solution for avionics & defense
    PDF, 1.2 Мб, Файл опубликован: 23 сен 2015
  • Keystone II DDR3 Initialization
    PDF, 73 Кб, Файл опубликован: 26 янв 2015
    This application report provides a step-to-step initialization guide for the Keystone II device DDR3 SDRAM controller.
  • Power Management of KS2 Device (Rev. C)
    PDF, 61 Кб, Версия: C, Файл опубликован: 15 июл 2016
    This application report lists the steps to enable Class 0 Temperature Compensation (Class 0 TC) mode of SmartReflexв„ў Subsystem (SRSS) module available on such devices.
  • Throughput Performance Guide for KeyStone II Devices (Rev. B)
    PDF, 866 Кб, Версия: B, Файл опубликован: 22 дек 2015
    This application report analyzes various performance measurements of the KeyStone II family of processors. It provides a throughput analysis of the various support peripherals to different end-points and memory access.
  • Keystone II DDR3 Debug Guide
    PDF, 143 Кб, Файл опубликован: 16 окт 2015
    This guide provides tools for use when debugging a failing DDR3 interface on a KeyStone II device.
  • Hardware Design Guide for KeyStone II Devices
    PDF, 1.8 Мб, Файл опубликован: 24 мар 2014
  • SERDES Link Commissioning on KeyStone I and II Devices
    PDF, 138 Кб, Файл опубликован: 13 апр 2016
    The serializer-deserializer (SerDes) performs serial-to-parallel conversions on data received from a peripheral device and parallel-to-serial conversion on data received from the CPU. This application report explains the SerDes transmit and receive parameters tuning, tools and some debug techniques for TI Keystone I and Keystone II devices.
  • PCIe Use Cases for KeyStone Devices
    PDF, 320 Кб, Файл опубликован: 13 дек 2011
  • Optimizing Loops on the C66x DSP
    PDF, 585 Кб, Файл опубликован: 9 ноя 2010
  • The C6000 Embedded Application Binary Interface Migration Guide (Rev. A)
    PDF, 20 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    The C6000 compiler tools support a new ELF-based ABI named EABI. Prior to this time, the compiler only supported a single ABI, which is now named COFF ABI. The following compelling best-in-class features are available under the C6000 EABI:GeneralZero-init globals: “int gvar;” gets set to 0 before main runs.Dynamic linking: Add code to a running system.Native ROM
  • Clocking Design Guide for KeyStone Devices
    PDF, 1.5 Мб, Файл опубликован: 9 ноя 2010
  • DDR3 Design Requirements for KeyStone Devices (Rev. B)
    PDF, 582 Кб, Версия: B, Файл опубликован: 5 июн 2014
  • Multicore Programming Guide (Rev. B)
    PDF, 1.8 Мб, Версия: B, Файл опубликован: 29 авг 2012
    As application complexity continues to grow, we have reached a limit on increasing performance by merely scaling clock speed. To meet the ever-increasing processing demand, modern System-On-Chip solutions contain multiple processing cores. The dilemma is how to map applications to multicore devices. In this paper, we present a programming methodology for converting applications to run on multicore
  • TI DSP Benchmarking
    PDF, 62 Кб, Файл опубликован: 13 янв 2016
    This application report provides benchmarks for the C674x DSP core, the C66x DSP core and the ARMВ®CortexВ®-A15 core. This document also shows how to reproduce these benchmarks on specific hardware platforms.
Серия: 66AK2L06 (4)
  • Semiconductors > Processors > Digital Signal Processors > C6000 DSP + ARM Processors > 66AK2x
На английском языке: Datasheet Texas Instruments 66AK2L06XCMSA2
