Datasheet Texas Instruments TAS5100IDAP — Даташит
СерияTAS5100
МодельTAS5100IDAP
Мощность цифрового усилителя мощностью 30 Вт 32-HTSSOP от -40 до 85
Pin32
Package TypeDAP
Industry STD TermHTSSOP
Width (мм)6.2
Length (мм)11
Thickness (мм)1.15
Max Height (мм)1.2
RoHSНе совместим
  • Digital Audio Measurements
    PDF, 136 Кб, Файл опубликован: 9 янв 2001
    To perform correct measurements on a true digital audio amplifier (TDAA), it is important to understnad the characteristics of the device, especially in comparison with conventional linear amplifiers such as Class-A and Class-AB. This report provides an overview of TI's proprietary digital amplification technology and information about how measurements on TDAA's must be performed in order to obtai
  • System Design Considerations for True Digital Audio Power Amplifiers (Rev. A)
    PDF, 675 Кб, Версия: A, Файл опубликован: 12 ноя 2001
    This report describes the conversion of pulse-code-modulated (PCM) to pulse-width-modulated (PWM) signals using Texas Instruments TDAA modulation devices (TAS50xx) and signal amplification using Texas Instruments family of H-bridge output stages (TAS51xx). It includes a detailed discussion of power supply voltage requirements, output circuit filters, and thermal dissipation. An example stereo appl
Серия: TAS5100 (2)
  • Semiconductors > Audio > Mid-Power Audio Amplifiers (5-50W) > Digital I2S Input Class-D
На английском языке: Datasheet Texas Instruments TAS5100IDAP
