Datasheet Texas Instruments LMH6645MA/NOPB — Даташит
СерияLMH6645
МодельLMH6645MA/NOPB
2.7V, 650ВµA, 55MHz, Rail-to-Rail Input and Output Amplifiers with Shutdown Option 8-SOIC -40 to 85
LMH664x 2.7 V, 650 uA, 55 MHz, Rail-to-Rail I/O Amplifiers w/Shutdown Option datasheet
PDF, 1.7 Мб, Версия: D, Файл опубликован: 25 ноя 2014
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY9595
CarrierTUBETUBE
МаркировкаLMH6645MA
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
2nd Harmonic62 dBc
3rd Harmonic72 dBc
@ MHz1
Acl, min spec gain1 V/V
Additional FeaturesN/A
АрхитектураBipolar,Voltage FB
BW @ Acl55 МГц
CMRR(Min)60 дБ
CMRR(Typ)84 дБ
GBW(Typ)55 МГц
Input Bias Current(Max)2000000 pA
Iq per channel(Max)1.6 мА
Iq per channel(Typ)0.725 мА
Количество каналов1
Offset Drift(Typ)5 uV/C
Output Current(Typ)20 мА
Rail-to-RailIn,Out
Slew Rate(Typ)22 V/us
Total Supply Voltage(Max)12 +5V=5, +/-5V=10
Total Supply Voltage(Min)2.5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)17 нВ/rtГц
Vn at Flatband(Typ)17 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)3 мВ
  • Evaluation Modules & Boards: LMH730216
    Evaluation Board for High-Speed Single Op Amp in the 5- 6-Pin SOT-23 Package
  • Evaluation Modules & Boards: LMH730227
    Evaluation Board for High-Speed Single Op Amp in the 8-Pin SOIC Package
  • AN-1515 A Comprehensive Study of the Howland Current Pump (Rev. A)
    PDF, 165 Кб, Версия: A, Файл опубликован: 26 апр 2013
    It is well known to analog experts that you can use the positive and negative inputs of an operationalamplifier to make a high-impedance current source (current pump) using a conventional operationalamplifier (op amp). This basic circuit can put out both + and - output current (or zero current) into variousloads. The theory is simple. But the practical problems involved are not so simple or
На английском языке: Datasheet Texas Instruments LMH6645MA/NOPB
