Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet ТI SN74LVC16245ADGVR — Даташит
СерияSN74LVC16245A
МодельSN74LVC16245ADGVR
Datasheet Texas Instruments SN74LVC16245ADGVR
16-битный шинный трансивер с выходами с 3 состояниями 48-TVSOP от -40 до 125
SN74LVC16245A 16-Bit Bus Transceiver With 3-State Outputs datasheet
PDF, 1.0 Мб, Версия: Q, Файл опубликован: 5 июн 2014
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Standard Transceiver
На английском языке: Datasheet Texas Instruments SN74LVC16245ADGVR
Политика конфиденциальности
