Datasheet Texas Instruments LMS8117ADTX-ADJ/NOPB — Даташит
Серия | LMS8117A |
Модель | LMS8117ADTX-ADJ/NOPB |
Линейный стабилизатор с фиксированным/регулируемым выходом 1 А/LDO 3-TO-252 от 0 до 125
LMS8117A 1-A Low-Dropout Linear Regulator datasheet
PDF, 651 Кб, Версия: F, Файл опубликован: 16 дек 2016
Pin | 3 | 3 |
Package Type | NDP | NDP |
Industry STD Term | TO-252 | TO-252 |
JEDEC Code | R-MSFM-L | R-MSFM-L |
Package QTY | 2500 | 2500 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | LMS8117 | ADT-ADJ |
Width (мм) | 6.1 | 6.1 |
Length (мм) | 6.58 | 6.58 |
Thickness (мм) | 2.3 | 2.3 |
Pitch (мм) | 4.57 | 4.57 |
Max Height (мм) | 2.55 | 2.55 |
Точность | 3 % |
Fixed Output Options | 1.8,3.3 В |
Iout(Max) | 1 A |
Iq(Typ) | 5 мА |
Рабочий диапазон температур | от 0 до 125 C |
Output Capacitor Type | Non-Ceramic |
Output Options | Adjustable Output,Fixed Output |
PSRR @ 100KHz | 37 дБ |
Package Group | TO-252 |
Package Size: mm2:W x L | 3TO-252: 65 mm2: 9.91 x 6.58(TO-252) PKG |
Rating | Catalog |
Regulated Outputs | 1 |
Special Features | N/A |
Thermal Resistance ОёJA | 56 В°C/W |
Vdo(Typ) | 1200 мВ |
Vin(Max) | 15 В |
Vin(Min) | 2.5 В |
Vout(Max) | 13.75 В |
Vout(Min) | 1.5 В |
- A Topical Index of TI LDO Application Notes (Rev. F)PDF, 82 Кб, Версия: F, Файл опубликован: 27 июн 2019
- Method For Cal Output Voltage Tolerances in Adj Regs (Rev. A)PDF, 284 Кб, Версия: A, Файл опубликован: 5 май 2013
When working with voltage regulator circuits the designer is often confronted with the need to calculatethe tolerance of the regulated output voltage. For fixed voltage regulators this problem is easily managedbecause the required information is directly supplied on the semiconductor manufacturer's data sheet. - AN-1482 LDO Regulator Stability Using Ceramic Output Capacitors (Rev. A)PDF, 169 Кб, Версия: A, Файл опубликован: 25 апр 2013
Ultra-low ESR capacitors such as ceramics are highly desirable because they can support fast-changingload transients and also bypass very high frequency noise coming from switching converter powersources which a linear regulator can not reject. However using ultra-low ESR capacitors on the output ofan LDO regulator requires that specific design changes be implemented to ensure loop stabili
Серия: LMS8117A (9)
LMS8117ADTXADJ/NOPB, LMS8117ADTX ADJ/NOPB
