Оптопары и оптореле Megawin
Datasheet Texas Instruments 74AC11086DRG4 — Даташит
Серия74AC11086
Модель74AC11086DRG4
Четырехвходовые вентили «исключающее ИЛИ» с 2 входами 16-SOIC от -40 до 85
Quadruple 2-Input Exclusive-OR Gate datasheet
PDF, 251 Кб, Версия: A, Файл опубликован: 1 апр 1996
Pin16
Package TypeD
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
Approx. Price (US$)0.94 | 1ku
Bits(#)4
F @ Nom Voltage(Max)(Mhz)100
ICC @ Nom Voltage(Max)(mA)0.04
Тип входаCMOS
Operating Temperature Range(C)-40 to 85
Output Drive (IOL/IOH)(Max)(mA)24/-24
Тип выходаCMOS
Schmitt TriggerNo
Technology FamilyAC
VCC(Max)(V)5.5
VCC(Min)(V)3
Voltage(Nom)(V)3.3
5
tpd @ Nom Voltage(Max)(ns)10.6
7.6
RoHSНе совместим
  • Live Insertion
  • Introduction to Logic
  • Shelf-Life Evaluation of Lead-Free Component Finishes
    PDF, 1.3 Мб, Файл опубликован: 24 май 2004
    The integrated circuit (IC) industry is converting to lead (Pb)-free termination finishes for leadframe-based packages. IC component users need to know the maximum length of time that components can be stored prior to being soldered. This study predicts shelf life of the primary Pb-free finishes being proposed by the industry. Components were exposed to a controlled environment, with known aging a
  • Semiconductors > Logic > Gate > XOR (Exclusive OR) Gate
На английском языке: Datasheet Texas Instruments 74AC11086DRG4
