Линейка продуктов KEEN SIDE
Datasheet Texas Instruments TPS40000DGQRG4 — Даташит
СерияTPS40000
МодельTPS40000DGQRG4
Низкий входной сигнал (2,25–5,5 В), частота 300 кГц, синхронный понижающий контроллер, только источник 10-MSOP-PowerPAD от -40 до 85
TPS40000 Synchronous Buck Controller datasheet
PDF, 1.0 Мб, Версия: D, Файл опубликован: 14 ноя 2005
Pin10
Package TypeDGQ
Industry STD TermHVSSOP
JEDEC CodeS-PDSO-G
Package QTY2500
Маркировка40000
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Pitch (мм).5
Max Height (мм)1.1
Control ModeVoltage Mode
Duty Cycle(Max)94 %
Iout(Max)15 A
Iq(Typ)1.5 мА
Number of Phases1
Package GroupMSOP-PowerPAD
Regulated Outputs1
Special FeaturesEnable,Synchronous Rectification
Switching Frequency(Max)300 kHz
Switching Frequency(Min)300 kHz
ТипController
Vin(Max)5.5 В
Vin(Min)2.25 В
Vout(Max)4 В
Vout(Min)0.7 В
  • Predictive Gate Drive (tm) FAQ
    PDF, 152 Кб, Файл опубликован: 3 фев 2003
    The proprietary Predictive Gate Driveв„ўtechnology from Texas Instruments maximizes efficiencies of today's high frequency, low output voltage, synchronous buck converters. To gain a better understanding of this innovative new control technique, this list of frequently asked questions (FAQs) addresses the Predictive Gate Driveв„ў technique.
  • Predictive Gate Drive Boosts Converter Efficiency
    PDF, 376 Кб, Файл опубликован: 18 дек 2002
    Predictive Gate Driveв„ў is a novel digital control-driven technique that optimizes MOSFET turn-on and turn-off delays in synchronous rectifiers. It uses a closed loop feedback system to detect body-diode conduction, and continuously adjusts dead-time delays to minimize the conduction time interval. Depending upon operating frequency and output voltage, the Predictive Gate Driveв„ў control
  • UCC27221/2 Predictive Gate Drive FAQ
    PDF, 211 Кб, Файл опубликован: 18 дек 2002
    The UCC27221/2 High-Efficiency Predictive Synchronous Buck Driver from Texas Instruments, employs the proprietary Predictive Gate Driveв„ў technology to maximize efficiencies of today's high frequency, low output voltage, synchronous buck converters. To gain a better understanding of this innovative new control technique, a list of frequently asked questions (FAQs) has been developed to addres
  • TI Power Solutions Power Up Altera FPGAs
    PDF, 167 Кб, Файл опубликован: 18 окт 2002
    Power requirements and power consumptions for Altera FPGAs including ACEX 1K APEX II Mercury and Stratix families are summarized and calculated at typical applications as a first?cut estimation for engineers designing with those multivoltage families. Design examples which cover LDOs SWIFT DC/DC controllers and power modules are demonstrated. Certain sequencing strategy is shown in each des
  • Automated Frequency Response Analyzer
    PDF, 939 Кб, Файл опубликован: 9 окт 2013
    This application report discusses a new method of doing stability Analysis testing by using basic labequipment, while not requiring any specific instruments.
  • PowerPAD Thermally Enhanced Package (Rev. H)
    PDF, 983 Кб, Версия: H, Файл опубликован: 6 июл 2018
Серия: TPS40000 (4)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Controller (External Switch)
На английском языке: Datasheet Texas Instruments TPS40000DGQRG4
