Datasheet Texas Instruments LMH6622MA — Даташит
СерияLMH6622
МодельLMH6622MA
Двойные широкополосные, малошумящие, 160 МГц, операционные усилители 8-SOIC от -40 до 85
LMH6622 Dual Wideband, Low Noise, 160 MHz, Operational Amplifiers datasheet
PDF, 1.5 Мб, Версия: E, Файл опубликован: 25 июл 2014
Package TypeD
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Рекомендуемая замена
ReplacementLMH6622MA/NOPB
Replacement CodeS
2nd Harmonic(dBc)90
3rd Harmonic(dBc)100
@ MHz1
Acl, min spec gain(V/V)2
Additional FeaturesDecompensated
Approx. Price (US$)1.42 | 1ku
АрхитектураBipolar
Voltage FB
BW @ Acl(MHz)160
CMRR(Min)(dB)80
CMRR(Typ)(dB)100
GBW(Typ)(MHz)320
Input Bias Current(Max)(pA)10000000
Iq per channel(Max)(mA)6
Iq per channel(Typ)(mA)4.3
Number of Channels(#)2
Offset Drift(Typ)(uV/C)2.5
Operating Temperature Range(C)-40 to 85
Output Current(Typ)(mA)90
Package Size: mm2:W x L (PKG)8SOIC: 29 mm2: 6 x 4.9(SOIC)
Slew Rate(Typ)(V/us)80
Total Supply Voltage(Max)(+5V=5, +/-5V=10)12
Total Supply Voltage(Min)(+5V=5, +/-5V=10)5
Vn at Flatband(Typ)(nV/rtHz)1.6
Vos (Offset Voltage @ 25C)(Max)(mV)1.2
RoHSНе совместим
  • Evaluation Modules & Boards: LMH730123
    Evaluation Board for High-Speed Dual Op Amp in the 8-Pin MSOP Package
  • Evaluation Modules & Boards: LMH730036
    Evaluation Board for High-Speed Dual Op Amp in the 8-Pin SOIC Package
  • Transimpedance Amplifiers (TIA): Choosing the Best Amplifier for the job (Rev. A)
    PDF, 153 Кб, Версия: A, Файл опубликован: 16 май 2017
    This application note is intended as a guide for the designer looking to amplify the small signal from a photodiode or avalanche diode so that it would be large enough for further processing (e.g. data acquisition) or to trigger some other event in a system. The challenge in doing so, as always, is to not degrade the signal such that it becomes indistinguishable from random noi
На английском языке: Datasheet Texas Instruments LMH6622MA
