Datasheet Texas Instruments TMS320F241PGAG4 — Даташит
СерияTMS320F241
МодельTMS320F241PGAG4
16-битный DSP с фиксированной точкой, 5 В и флэш-памятью 64-QFP от -40 до 85
Pin64
Package TypePG
Industry STD TermQFP
JEDEC CodeR-PQFP-G
МаркировкаTMS320F241PGA
Width (мм)14
Length (мм)20
Thickness (мм)2.7
Pitch (мм)1
Max Height (мм)3.1
RoHSНе совместим
  • Speed Field-Oriented Control of a 3-Phase AC Motor Using the TMS320F240
    PDF, 338 Кб, Файл опубликован: 1 янв 1998
    Since the integration of high computational DSP power with all necessary motor control peripherals into a single chip, TMS320F240, it has become possible to design and implement a highly efficient and accurate AC induction drive control. The AC induction drive presented here is based on document [6] and on a dedicated and exhaustive study of this DSP solution. Both the theoretical and practica
  • Power Drive Protection Interrupt
    PDF, 47 Кб, Файл опубликован: 21 фев 2000
    The Power Drive Protection Interrupt (PDPINT) pin is a safety feature that is built into all TMS320C24? DSPs. This feature protects the electrical drive from damage due to any electrical, mechanical or thermal abnormalities. When this pin is driven low externally, all the PWM outputs are put in a high impedance state, thereby protecting the electrical drive from further damage. A proper understand
  • COFF to DSK Translator
    PDF, 29 Кб, Файл опубликован: 29 апр 1999
    Development platforms available for digital signal processor (DSP) designers today are mainly the evaluation module (EVM) and the DSP starter kit (DSK). Executable code generated on these two platforms is not compatible and migration from one platform to the other is not straight forward.This application report presents a description of a utility designed to translate the executables produced
  • DSP Solution for Permanent Magnet Synchronous Motor
    PDF, 210 Кб, Файл опубликован: 1 янв 1996
    This document presents a solution to control a permanent magnet synchronous motor using the TMS320C24x. This new family of DSPs enables cost-effective design of intelligent controllers for brushless motors which can fulfill enhanced operations, consisting of fewer system components, lower system cost and increased performances. The control method presented relies on the field orientated control (F
  • Programming examples for the TMS320C24x/C240x CAN (Rev. A)
    PDF, 322 Кб, Версия: A, Файл опубликован: 17 апр 2003
    The 24x (TMS320F243 and TMS320F241) and 240xA (TMS320LF2407A, 2406A, and 2403A) series of digital signal processor (DSP) controllers feature an on-chip Controller Area Network (CAN) module. This module is a Full-CAN controller, compliant with CAN specification 2.0B. This application report describes the operation of the CAN module and its control registers. Several programming examples have been
  • Implementation of a Speed Controlled Brushless DC Drive Using TMS320F240
    PDF, 157 Кб, Файл опубликован: 1 янв 1997
    The DSP Controller TMS320F240 from Texas Instruments is suitable for a wide range of motor drives. TMS320F240 provides a single chip solution by integrating on-chip not only a high computational power but, also, all the peripherals necessary for electric motor control. The main benefits are increased system reliability and cost reduction of the overall system. The present application note describ
  • DSP Solution for AC Induction Motor
    PDF, 183 Кб, Файл опубликован: 1 янв 1996
    The Motor Control industry is a strong aggressive sector. Each industry to remain competitive, must reduce costs but also has to answer to power consumption reduction and EMI radiation reduction issues imposed by governments and power plant lobbies. The results of these constraining factors are the need of enhanced algorithms. DSP technology allows to achieve both, a high level of performance as
  • Implementing JPEG with TMS320C2xx Assembly Language Software
    PDF, 129 Кб, Файл опубликован: 29 ноя 1999
    JPEG compression/decompression technique is widely used for still image applications. There are two major ways to implement JPEG algorithm--hardware and software. The hardware approach is good for speed but it has less flexibility and it costs more.The software approach, on the other hand, is less expensive and more flexible. Implementing JPEG with TMS320C2xx DSP software is a good solution fo
  • Implementing Triple Conversion Single Phase Online UPS Using TMS320C240 (Rev. A)
    PDF, 995 Кб, Версия: A, Файл опубликован: 7 сен 1999
    Uninterruptible power supplies (UPS) play an important role in interfacing critical loads such as computers, communication systems, medical/life support systems, and industrial controls to the utility power grid. Among the various UPS topologies, on-line UPS provides the most protection to such loads against any utility power problem. However, because of the multiple power conversion stages, on-li
  • Using C to Access Data Stored in Program Space Memory on the TMS320C24x DSP
    PDF, 106 Кб, Файл опубликован: 15 апр 2002
    Efficient utilization of available memory in a TMS320C24x? DSP sometimes requires the placement of data in program space memory (as opposed to data space memory). In particular, the on-chip flash (or ROM) in the program space provides a large nonvolatile memory for storing constant arrays, look-up tables, and string tables. However, accessing this data using the C programming language is problemat
  • Average Current Mode Controlled Power Factor Correction Converter..TMS320LF2407A (Rev. A)
    PDF, 297 Кб, Версия: A, Файл опубликован: 19 июл 2005
    Low cost, high performance DSP controllers with integrated peripherals such as, analog-to-digital (A/D) converters and pulse width modulator (PWM), have enabled the power supply designers with a new tool for implementing control for their power conversion functions. However, the power designers with mostly analog control experience are faced with new challenges as they start to adopt this new tech
  • Interfacing TMS320C20x DSPs to Intel 28Fxxx Flash Memories
    PDF, 39 Кб, Файл опубликован: 4 авг 1999
    This application report describes how the Texas Instruments (TI)(tm) TMS320C20x digital signal processor (DSP) can be interfaced to the Intel(tm) 28F010 flash memory. The 28Fxxx flash memory are 5V memories that use a 12V supply to modify the contents of the flash memory. A full C implementation of the quick-erase and quick-pulse programming algorithm for the ?C20x DSPs is included.
  • Writing a C Callable Assembly Function Using the TMS320C2000
    PDF, 36 Кб, Файл опубликован: 16 авг 1999
    Mixing C and assembly language is an important task of digital signal processing (DSP) programming. It is very common for a software designer to write the kernel in C language and write some critical functions in DSP assembly language for improving the performance. This application report introduces you to writing a C callable assembly function for the Texas Instruments (TI)(tm) TMS320C2000 genera
  • Implementing Speech-Recognition Algorithms on the TMS320C2xx Platform
    PDF, 97 Кб, Файл опубликован: 1 апр 1998
    This application report presents the hidden-Markov-model-based speech-recognition system using a 16-bit fixed-point digital signal processor (DSP) from Texas Instruments (TI). It addresses the problems that have been encountered and the compromises that have been made to implement the hidden-Markov-model-based isolated-word recognizer using the TI TMS320C2xx DSP. This report addresses fixed-point
  • Cost-Effective, Simple Power Supply Solution forTMS320C24x DSPs
    PDF, 85 Кб, Файл опубликован: 30 май 2001
    The task of generating a power supply for DSPs in space-constrained control applications can be a challenging task because of the need to minimize its cost and size. Therefore, this application report provides information on a simplified approach for designing a power supply. A sophisticated power supply controller and a novel power-conversion topology are introduced that minimize external compone
  • Implementation of Speed Field Oriented Control of 3-Phase PMSM Motor Using 'F240
    PDF, 539 Кб, Файл опубликован: 12 авг 1999
    This application report presents a solution to control a 3-phase Permanent Magnet Synchronous motor using the Texas Instruments (TItm) TMS320F240 digital signal processor (DSP). This processor is part of a new family of DSPs that enable cost-effective design of intelligent controllers for brushless motors. The use of this DSP yields enhanced operations, fewer system components, lower system cost a
  • Implem. of a Current Controlled Switched Reluctance Motor Drive Using TMS320F240
    PDF, 340 Кб, Файл опубликован: 1 июн 1997
    The DSP controller TMS320F240 from Texas Instruments is suitable for a wide range of motor drives and power electronic applications. TMS320F240 reduces chip count of a system by integrating most of the important power electronics peripherals on chip and thus increases system reliability and reduces system cost. This application note describes complete implementation of a current controlled Switche
  • Getting Started in C and Assembly Code with the TMS320LF240x DSP (Rev. A)
    PDF, 421 Кб, Версия: A, Файл опубликован: 10 июл 2002
    This application report presents basic code for initializing and operating the TMS320LF240x DSP devices. Two functionally equivalent example programs are presented: one written in assembly language and the other in C language. Detailed discussions of each program are provided that explain numerous compiler and assembler directives, code requirements, and hardware-related requirements. The programs
  • Switched Reluctance Motor Control - Operation & Example Using TMS320F240 (Rev. A)
    PDF, 306 Кб, Версия: A, Файл опубликован: 21 сен 1999
    This report describes the basic operation of switched reluctance motors (SRMs) and demonstrates how a TMS320F240 DSP-based SRM drive from Texas Instruments (TM) can be used to achieve a wide variety of control objectives. The first part of the report offers a detailed review of the operation and characteristics of SRMs. The advantages and disadvantages of this type of motor are cited. The second p
  • TMS320F240 DSP Solution for Obtaining Resolver Angular Position and Speed (Rev. A)
    PDF, 340 Кб, Версия: A, Файл опубликован: 8 авг 2017
    Thisapplicationreportfirst presentsa TMS320F240DSPsolutionand thenanotheruniqueapproachusingPGA411-Q1for obtainingthe angularpositionand speedof a resolver.A resolveris an absolutemechanicalpositionsensorused,for example,in servoapplications.It isbasicallya rotatingtransformer.The sinusoidalinputreferenceis amplitudemodulatedw
  • Motor Speed Measurement Considerations Using TMS320C24x DSPs
    PDF, 99 Кб, Файл опубликован: 17 авг 2001
    The TMS320C24x? generation of DSPs provide appropriate internal hardware for interfacing with low-cost, external-speed sensors for motor speed measurement applications. The periodic output signal from the speed sensor is applied to the capture input pin of the DSP and the signal?s period is measured. This information is then used to calculate the motor speed. However, this calculation of motor spe
  • Code Composer Studioв„ў IDE v2.2 Profiler
    PDF, 57 Кб, Файл опубликован: 7 апр 2003
    This application note will outline and discuss the Code Composer Studio Profiler and how to use it in accurately profiling an application. We will explain the various types of profiling and will detail the differences between simulator profiling and emulator profiling.Requirements:Windows 98 (SP1/SE), Windows NT SP6, Windows 2000 (SP1/SP2), Windows XP Home and ProCode Co
  • A Software Modularity Strategy for Digital Control Systems
    PDF, 499 Кб, Файл опубликован: 6 сен 2000
  • DSP Solutions for the Switched Reluctance Motor
    PDF, 112 Кб, Файл опубликован: 1 янв 1997
    This document deals with solutions to control a switched reluctance motor using the TMS320C24x. This new DSP family enables cost-effective design of intelligent controllers for switched reluctance motors. Two speed control algorithms are presented, they allow the Switched Reluctance motor drive to reach high efficiency, smooth operation, very good dynamic behavior, very high speed and low acoustic
  • A Variable-Speed Sensorless Drive System for Switched Reluctance Motors
    PDF, 246 Кб, Файл опубликован: 30 окт 1999
    With the advent of high-speed digital signal processors (DSPs) specialized for motion control applications, it has become possible to control motors without mechanical (speed or position) sensors. This is achieved by algorithms that estimate the desired quantities in real time, based on the electrical signals in the motor windings. Benefits include cost savings and improved reliability due to redu
  • 3.3 V DSP for Digital Motor Control
    PDF, 138 Кб, Файл опубликован: 29 апр 1999
    New generations of motor control digital signal processors (DSPs) lower their supply voltages from 5V to 3.3V to offer higher performance at lower cost. Replacing traditional 5V digital control circuitry by 3.3V designs introduce no additional system cost and no significant complication in interfacing with TTL and CMOS compatible components, as well as with mixed voltage ICs such as power transist
  • Migrating Code Composer v4.12 Projects to Code Composer Studio v2.0
    PDF, 117 Кб, Файл опубликован: 11 июл 2002
    This application report describes the process of migrating an existing Code Composer v4.12 project to a Code Composer Studio? Integrated Development Environment (IDE) v2 project.
  • Flash Programming Solutions for the TMS320F28xxx DSCs
    PDF, 423 Кб, Файл опубликован: 19 авг 2008
    Flash programming is a process that occurs during all stages of a TMS320F28xxx digital signal controller (DSC) development cycle: firmware debug, prototyping, production, and field reprogramming. Several solutions are available to accommodate programming for all of these development stages. This application report presents solutions that are available and at what stage in the development cycle the
  • Semiconductors > Microcontrollers (MCU) > Performance MCUs > Real-time Control > C24x 16-bit Series
На английском языке: Datasheet Texas Instruments TMS320F241PGAG4
