Datasheet Texas Instruments OPA637AUE4 — Даташит
СерияOPA637
МодельOPA637AUE4
Прецизионные высокоскоростные операционные усилители Difet(R) 8-SOIC от -25 до 85
OPA627 and OPA637 Precision High-Speed DifetВ® Operational Amplifiers datasheet
PDF, 1.4 Мб, Версия: A, Файл опубликован: 16 апр 2015
Package TypeD
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Acl, min spec gain(V/V)1.7
Additional FeaturesDecompensated
Vos Adj Pin
Approx. Price (US$)12.86 | 1ku
АрхитектураFET
Voltage FB
BW @ Acl(MHz)16
CMRR(Min)(dB)100
CMRR(Typ)(dB)110
GBW(Typ)(MHz)80
Input Bias Current(Max)(pA)5
Iq per channel(Max)(mA)7.5
Iq per channel(Typ)(mA)7
Number of Channels(#)1
Offset Drift(Typ)(uV/C)0.4
Operating Temperature Range(C)-25 to 85
Output Current(Typ)(mA)45
Rail-to-RailIn
Out
Slew Rate(Typ)(V/us)100
Total Supply Voltage(Max)(+5V=5, +/-5V=10)36
Total Supply Voltage(Min)(+5V=5, +/-5V=10)9
Vn at Flatband(Typ)(nV/rtHz)4.5
Vos (Offset Voltage @ 25C)(Max)(mV)0.1
RoHSНе совместим
  • Fast Settling Low-Pass Filter
    PDF, 101 Кб, Файл опубликован: 27 сен 2000
    Noise reduction by filtering is the most commonly used method for improving signal-to-noise ratio. The increase in settling time, however, can be a serious disadvantage in some applications such as high-speed data acquisition systems. The nonlinear filter described here is a simple way to get a four-to-one improvement in settling time as compared to a conventional filter.
  • OPA627, OPA637 EMI Immunity Performance (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 2 ноя 2012
  • Improved Device Noise Performance For the 3650 Isolation Amplifier
    PDF, 28 Кб, Файл опубликован: 27 сен 2000
    The 3650 is an optically coupled, differential input, isolation amplifier having programmable gain. Noise for the 3650 is specified to 4u Vrms (typ) on the input stage of the isolation barrier and 65u Vrms (typ) on the output stage. The gain of the 3650 is controlled using exernal resistors on the input stage. In low gains, the noise performance of the 3650 is dominated by the output stage noise f
  • Composite Op Amp Gives You The Best of Both Worlds
    PDF, 32 Кб, Файл опубликован: 27 сен 2000
    Classical op amps such as the OPA627 have excellent performance in applications where the required gain bandwidth is low compared to the gain-bandwidth product of the op amp. However, increasing closed-loop gain decreases the error-reducing loop gain. Furthermore, starting at relatively low frequencies, the loop gain rolls-off at 20dB/decade of signal frequency increase. In combination these effec
  • Comparison of Noise Performance of FET Transimpedence Amp/Switched Integrator
    PDF, 66 Кб, Файл опубликован: 27 сен 2000
    Low-input current FET operational amplifiers are universlly used to monitor photodetector, or more commonly photodiode currents. These photodetectors bridge the gap between a physical event, light, and electronics. There are a variey of amplifier configurations to select from and the choice is based on noise, bandwidth, offset, and linearity. A considerable amount has been written on the performan
  • Compensate Transimpedance Amplifiers Intuitively (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
    Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved.
На английском языке: Datasheet Texas Instruments OPA637AUE4
