Datasheet Texas Instruments SN74LVCH16543ADGGR — Даташит
СерияSN74LVCH16543A
МодельSN74LVCH16543ADGGR
16-битный регистровый трансивер с выходами с 3 состояниями 56-TSSOP от -40 до 85
SN74LVCH16543A datasheet
PDF, 1.0 Мб, Версия: M, Файл опубликован: 7 окт 2003
Pin56
Package TypeDGG
Industry STD TermTSSOP
Package QTY2000
МаркировкаLVCH16543A
Width (мм)6.1
Length (мм)14
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
Bits16
F @ Nom Voltage(Max)100 Mhz
ICC @ Nom Voltage(Max)0.02 мА
Output Drive (IOL/IOH)(Max)-24/24 мА
Package GroupTSSOP
Package Size: mm2:W x L56TSSOP: 113 mm2: 8.1 x 14(TSSOP) PKG
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)3.6 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,2.7,3.3 В
tpd @ Nom Voltage(Max)6.1,5.4 нс
  • Bus-Hold Circuit
    PDF, 418 Кб, Файл опубликован: 5 фев 2001
    When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Registered Transceiver
На английском языке: Datasheet Texas Instruments SN74LVCH16543ADGGR
