Datasheet Texas Instruments THS4051MJGB — Даташит
СерияTHS4051M
МодельTHS4051MJGB
Высокоскоростной усилитель 70 МГц 8-CDIP от -55 до 125
Pin88
Package TypeJGJG
Industry STD TermCDIPCDIP
JEDEC CodeR-GDIP-TR-GDIP-T
Package QTY11
CarrierTUBETUBE
МаркировкаTHS4051M9959901QPA
Width (мм)6.676.67
Length (мм)9.69.6
Thickness (мм)4.574.57
Pitch (мм)2.542.54
Max Height (мм)5.085.08
Additional FeaturesN/A
АрхитектураVoltage FB
Bipolar
CMRR(Min)(dB)70
CMRR(Typ)(dB)100
GBW(Typ)(MHz)70
IIB(Max)(pA)6000000
Iq per channel(Max)(mA)10.5
Iq per channel(Typ)(mA)8.5
Number of Channels(#)1
Offset Drift(Typ)(uV/C)15
Operating Temperature Range(C)-55 to 125
Output Current(Typ)(mA)100
Package GroupCDIP
Package Size: mm2:W x L (PKG)See datasheet (CDIP)
Rail-to-RailNo
RatingMilitary
Slew Rate(Typ)(V/us)240
Total Supply Voltage(Max)(+5V=5, +/-5V=10)32
Total Supply Voltage(Min)(+5V=5, +/-5V=10)9
Vn at 1kHz(Typ)(nV/rtHz)14
Vos (Offset Voltage @ 25C)(Max)(mV)10
RoHSTBD
  • Semiconductors > Space & High Reliability > Amplifier > Operational Amplifiers
На английском языке: Datasheet Texas Instruments THS4051MJGB
