Datasheet Texas Instruments OPA227UA/2K5G4 — Даташит
СерияOPA227
МодельOPA227UA/2K5G4
Высокоточные малошумящие операционные усилители 8-SOIC от -40 до 85
OPAx22x High Precision, Low Noise Operational Amplifiers datasheet
PDF, 1.6 Мб, Версия: B, Файл опубликован: 30 июн 2015
Pin888
Package TypeDDD
Industry STD TermSOICSOICSOIC
Package QTY250025002500
CarrierLARGE T&RLARGE T&RLARGE T&R
МаркировкаA227UOPA
Width (мм)3.913.913.91
Length (мм)4.94.94.9
Thickness (мм)1.581.581.58
Pitch (мм)1.271.271.27
Max Height (мм)1.751.751.75
Additional FeaturesN/A
АрхитектураBipolar
CMRR(Min)120 дБ
CMRR(Typ)138 дБ
GBW(Typ)8 МГц
Input Bias Current(Max)10000 pA
Iq per channel(Max)3.8 мА
Iq per channel(Typ)3.7 мА
Количество каналов1
Offset Drift(Typ)0.1 uV/C
Output Current(Typ)45 мА
Rail-to-RailIn,Out
Slew Rate(Typ)2.3 V/us
Total Supply Voltage(Min)5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)3 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.075 мВ
  • AB-174: Getting the Full Potential from your ADC (Rev. A)
    PDF, 72 Кб, Версия: A, Файл опубликован: 28 июн 2002
    Many of today?s high-resolution ADCs (Analog-to-Digital Converters) are operating from a single supply and use fully differential inputs. This can be a problem for single-ended signals that are bipolar relative to common. This article illustrates circuit configurations that preserve the full-scale input range by using modern features, such as Programmable Gain Amplifiers (PGAs) and internal voltag
  • Optoelectronics Circuit Collection
    PDF, 261 Кб, Файл опубликован: 11 июн 2001
    This application report presents a collection of analog circuits that may be useful in electro-optic applications such as optical networking. The circuits are Avalanche Photodiode Bias Supply 1; Linear TEC Driver-1, -2, and -3; Laser Diode Driver-1 and -2; and Temperature Under- and Over-range Sensing with a Window Comparator.
  • Tuning in Amplifiers
  • OPA227, OPA2227, OPA4227, OPA228, OPA2228, OPA4228 EMI Immunity Performance (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 2 ноя 2012
  • Topology and Noise Using Multiplying DACs (Rev. A)
    PDF, 347 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Numerical Protection Relay Solution
    PDF, 187 Кб, Файл опубликован: 2 сен 2010
    Numerical Protection Relays (NPRs) are critical elements in any power distribution network. Generally, there are several different types of NPRs. Each type, however, shares a similar architecture, thus enabling designers to build an entire system solution that is based on a relatively small number of flexible components. This application note demonstrates how an NPR can be implemented using TI's e
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA227UA/2K5G4
