Datasheet Texas Instruments UC2823DWTRG4 — Даташит
| Серия | UC2823 |
| Модель | UC2823DWTRG4 |
Высокоскоростной ШИМ-контроллер 16-SOIC от -25 до 85
High Speed PWM Controller datasheet
PDF, 2.9 Мб, Версия: B, Файл опубликован: 5 авг 2009
Купить UC2823DWTRG4 на РадиоЛоцман.Цены — от 103 до 219 ₽12 предложений от 12 поставщиков IC REG CTRLR MULT TOP 16SOIC. Buck, Boost, Flyback, Forward Converter Regulator Positive Output Step-Up, Step-Down, Step-Up/Step-Down DC-DC Controller IC 16-SOIC.... | |||
| UC2823DWTRG4 Texas Instruments | 103 ₽ | ||
| UC2823DWTRG4 Texas Instruments | 168 ₽ | ||
| UC2823DWTRG4 Texas Instruments | по запросу | ||
| Pin | 16 |
| Package Type | DW |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | UC2823DW |
| Width (мм) | 7.5 |
| Length (мм) | 10.3 |
| Thickness (мм) | 2.35 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 2.65 |
| Mechanical Data | Скачать |
| Control Method | Current,Voltage |
| Duty Cycle(Max) | 80 % |
| Frequency(Max) | 1000 kHz |
| Frequency(Min) | 0.1 kHz |
| Gate Drive(Typ) | 1.5 A |
| Рабочий диапазон температур | от -25 до 85 C |
| Package Group | SOIC |
| Rating | Catalog |
| Special Features | Error Amplifier,Multi-topology,Soft Start,Synchronization Pin |
| Topology | Boost,Buck,Flyback,Forward |
| UVLO Thresholds On/Off | 9.2/8.4 В |
| Vin(Max) | 30 В |
| Vin(Min) | 8.4 В |
- U-131 Simple Switchmode Lead-Acid Battery ChargerPDF, 206 Кб, Файл опубликован: 5 сен 1999
Lead-acid batteries are finding considerable use as bothprimary and backup power sources. For complete batteryutilization the charger circuit must charge the batteryto full capacity while minimizing over-charging forextended battery life. Since battery capacity varies withtemperature the charger must vary the amount of chargewith temperature to realize maximum capacity and life.Si
Серия: UC2823 (5)
- UC2823DW UC2823DWG4 UC2823DWTR UC2823DWTRG4 UC2823N
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
