Datasheet Texas Instruments TUSB3410VF — Даташит
СерияTUSB3410
МодельTUSB3410VF
Последовательный порт UART/I2C/IrDA — мост USB 32-LQFP 0–70
TUSB3410 USB to Serial Port Controller datasheet
PDF, 2.5 Мб, Версия: J, Файл опубликован: 10 июл 2017
Pin32
Package TypeVF
Industry STD TermLQFP
JEDEC CodeS-PQFP-G
Package QTY250
CarrierJEDEC TRAY (10+1)
МаркировкаTUSB3410
Width (мм)7
Length (мм)7
Thickness (мм)1.4
Pitch (мм).8
Max Height (мм)1.6
Package GroupLQFP
Package Size: mm2:W x L32LQFP: 81 mm2: 9 x 9(LQFP) PKG
USB Speed12 Mbps
  • Evaluation Modules & Boards: TUSB3410UARTPDK
    TUSB3410UARTPDK Evaluation Module
  • Evaluation Modules & Boards: USB-CTM-MINIDK-EVM
    USB Type-Cв„ў Minidock Board With Video and Charging Support Evaluation Module
  • Evaluation Modules & Boards: DP159RGZEVM
    DP159RGZEVM Evaluation Module
  • Evaluation Modules & Boards: TMDS171RGZEVM
    TMDS171RGZ 3.4 Gbps TMDS Retimer Evaluation Module
  • Evaluation Modules & Boards: DP159RSBEVM
    DP159RSBEVM Evaluation Module
  • Evaluation Modules & Boards: TMDS181RGZEVM
    TMDS181RGZ 6 Gbps TMDS Retimer Evaluation Module
  • Evaluation Modules & Boards: DP149RSBEVM
    DP149 3.4 Gbps DP++ to HDMI Retimer Evaluation Module
  • Evaluation Modules & Boards: TDP158RSBEVM
    6 Gbps AC Coupled to TMDSВ™/HDMIВ™ Redriver Evaluation Module
  • USB/Serial Applications Using TUSB3410 VCP Software (Rev. F)
    PDF, 271 Кб, Версия: F, Файл опубликован: 8 июн 2011
  • TUSBWINVCP Customization Guide
    PDF, 320 Кб, Файл опубликован: 17 июн 2011
  • VIDs, PIDs, and Firmware: Design Decisions When Using TI USB Device Controllers
    PDF, 162 Кб, Файл опубликован: 24 сен 2003
    System designers using TI USB controller devices must make certain design decisions involving the vendor ID (VID) and product ID (PID) of the USB device and the location of firmware. If these are not configured properly, the device will not be enumerated correctly by the USB host.This document discusses how these are handled within a system using one of the TI USB device controllers. These con
  • MSP430 USB Connectivity Using TUSB3410 (Rev. A)
    PDF, 923 Кб, Версия: A, Файл опубликован: 9 окт 2006
    This application report presents a ready-to-use USB connectivity reference design for MSP430 microcontrollers using the Texas Instruments TUSB3410 USB-to-serial bridge controller. The provided solution enables high-speed data transfers with speeds of up to 921,600 bit/s as well as MSP430 Flash code download through the USB port. The reference design includes MSP430 and PC software, drivers, schema
  • TMS320F280x DSC USB Connectivity Using TUSB3410 USB-to-UART Bridge Chip
    PDF, 511 Кб, Файл опубликован: 26 май 2006
    USB connectivity on the TMS320F280xв„ў family of Digital Signal Controllers may be achieved using the TUSB3410 USB 2.0 to UART bridge chip. All needed USB descriptors and firmware for the TUSB3410 device are bootable from the on-chip memory of the TMS320F280x device through the I2C port, and hence an external EEPROM is not needed in the system. A USB development system for the TMS320F2808 is e
  • Semiconductors > Interface > USB > USB Controllers and Transceivers
На английском языке: Datasheet Texas Instruments TUSB3410VF
