Datasheet Texas Instruments MSP430FR5857IRHAR — Даташит
| Серия | MSP430FR5857 |
| Модель | MSP430FR5857IRHAR |
MSP430FR5857 Микроконтроллер со сверхнизким энергопотреблением, частота 16 МГц, 32 КБ FRAM, 1 КБ SRAM, 33 ввода-вывода 40-VQFN от -40 до 85
MSP430FR58xx Mixed-Signal Microcontrollers      datasheet
PDF, 2.6 Мб, Версия: D, Файл опубликован: 9 мар 2017
|  Купить MSP430FR5857IRHAR на РадиоЛоцман.Цены — от 147 до 182 ₽ 9 предложений от 9 поставщиков IC MCU 16BIT 32KB FRAM 40VQFN. CPUXV2 MSP430TM FRAM Microcontroller IC 16-Bit 16MHz 32KB (32K x 8) FRAM 40-VQFN (6x6).... | |||
| MSP430FR5857IRHAR Texas Instruments | 159 ₽ | ||
| MSP430FR5857IRHAR Texas Instruments | 173 ₽ | ||
| MSP430FR5857IRHAR Texas Instruments | по запросу | ||
| Pin | 40 |
| Package Type | RHA |
| Industry STD Term | VQFN |
| JEDEC Code | S-PQFP-N |
| Package QTY | 2500 |
| Carrier | LARGE T&R |
| Маркировка | FR5857 |
| Width (мм) | 6 |
| Length (мм) | 6 |
| Thickness (мм) | .9 |
| Pitch (мм) | .5 |
| Max Height (мм) | 1 |
| Mechanical Data | Скачать |
| ADC | ADC12 - 14ch |
| AES | N/A |
| Active Power | 101.25 uA/MHz |
| Additional Features | Real-Time Clock,Watchdog,Temp Sensor,Brown Out Reset,IrDA |
| BSL | UART |
| CPU | MSP430 |
| Comparators | 16 |
| DMA | 3 |
| Featured | fr5 |
| Тактовая частота | 16 МГц |
| GPIO Pins | 33 |
| I2C | 1 |
| Max VCC | 3.6 |
| Min VCC | 1.8 |
| Multiplier | 32x32 |
| Non-volatile Memory | 32 KB |
| Package Group | VQFN |
| Package Size: mm2:W x L | 40VQFN: 36 mm2: 6 x 6(VQFN) PKG |
| RAM | 1 KB |
| Rating | Catalog |
| SPI | 3 |
| Security Enabler | Cryptographic acceleration,Debug security,Physical security,Secure FW and SW update,Software IP protection |
| Special I/O | N/A |
| Standby Power | 0.5 LPM3-uA |
| Timers - 16-bit | 5 |
| UART | 2 |
| Wakeup Time | 7 us |
- Evaluation Modules & Boards: MSP-EXP430FR5969
 MSP430FR5969 LaunchPad Development Kit
- Evaluation Modules & Boards: MSP-BNDL-FR5969LCD
 MSP430FR5969 LaunchPad Development Kit with Sharp В® Memory LCD BoosterPack Bundle
- Evaluation Modules & Boards: 430BOOST-SHARP96
- Development Kits: MSP-FET430U48C
 48-pin Target Development Board and MSP-FET Programmer Bundle for MSP430FRxx FRAM MCUs
- Evaluation Modules & Boards: MSP-TS430RGZ48C
 MSP-TS430RGZ48C - 48-pin Target Development Board for MSP430FRxx FRAM MCUs
- JTAG Emulators/ Analyzers: ENERGYTRACE
 MSP EnergyTrace Technology
- Migrating From MSP430F4xx Family to MSP430FR58xx/FR59xx/FR68xx/FR69xx Family (Rev. B)PDF, 183 Кб, Версия: B, Файл опубликован: 3 ноя 2016
 This application report enables easy migration from MSP430F4xx flash-based MCUs to the MSP430FR58xx/59xx/68xx/69xx family of FRAM-based MCUs. The intent is to highlight key differences between the two families. For more information on the use of the MSP430FR58xx/FR59xx/68xx/69xx devices, see the MSP430FR58xx, MSP430FR59xx, MSP430FR68xx, and MSP430FR69xx Family User's Guide.
- Getting Started With EEMBC ULPBench on MSP-EXP430FR5969 (Rev. A)PDF, 381 Кб, Версия: A, Файл опубликован: 29 янв 2015
 This is a getting started guide for obtaining the ULPMarkв„ў-CP score using the Embedded Microprocessor Benchmark Consortium (EEMBC) ULPBench and EnergyMonitor with the MSP430FR5969 microcontroller (MCU). This document uses the MSP-EXP430FR5969 LaunchPad development kit as the target evaluation module (EVM) for performing the benchmark.MSP430 Advanced Power Optimizations: ULP Advisor SW and EnergyTrace TechnologyPDF, 4.0 Мб, Файл опубликован: 9 июн 2014
 MSP430 microcontrollers are designed specifically for ultra-low-power applications. Features such as multiple low-power modes, instant wakeup, intelligent autonomous peripherals, and much more to enable such ultra-low-power capabilities. Texas Instruments provides valuable tools to help the programmer fully use these benefits and optimize power consumption of the target application. This appDesigning With the MSP430FR58xx, FR59xx, FR68xx, and FR69xx ADC (Rev. A)PDF, 137 Кб, Версия: A, Файл опубликован: 30 мар 2016
 Designing an application with the analog-to-digital converter (ADC) requires several considerations to optimize for power and performance. This application report discusses the basics of how you would analyze a data sheet and user's guide to design your application. It goes into the fundamentals of how to optimize your design based on the external requirements and available ADC configurations. TheMSP430 FRAM Technology – How To and Best PracticesPDF, 326 Кб, Файл опубликован: 23 июн 2014
 FRAM is a non-volatile memory technology that behaves similar to SRAM while enabling a whole host of new applications, but also changing the way firmware should be designed. This application report outlines the how to and best practices of using FRAM technology in MSP430 from an embedded software development perspective. It discusses how to implement a memory layout according to application-specifMSP430 FRAM Quality and Reliability (Rev. A)PDF, 295 Кб, Версия: A, Файл опубликован: 1 май 2014
 FRAM is a nonvolatile embedded memory technology and is known for its ability to be ultra-low power while being the most flexible and easy-to-use universal memory solution available today. This application report is intended to give new FRAM users and those migrating from flash-based applications knowledge on how FRAM meets key quality and reliability requirements such as data retention and enduraMigrating from the MSP430F5xx,F6xx Family to the MSP430FR58xx/FR59xx/68xx Family (Rev. D)PDF, 151 Кб, Версия: D, Файл опубликован: 3 ноя 2016
 This application report helps enable easy migration from MSP430F5xx and MSP430F6xx flash-based MCUs to the MSP430FR58xx/FR59xx/68xx/69xx FRAM-based MCUs. For the migration guide to MSP430FR57xx, see Migrating From the MSP430F2xx Family to the MSP430FR57xx Family. It covers programming, system, and peripheral considerations when migrating firmware. The intent is to highlight differences between theMigrating from the MSP430F2xx,G2xx Family to the MSP430FR58xx/FR59xx/68xx/69xx (Rev. E)PDF, 179 Кб, Версия: E, Файл опубликован: 3 ноя 2016
 This application report enables easy migration from MSP430F2xx flash-based MCUs to the MSP430FR58xx/FR59xx/68xx/69xx family of FRAM-based MCUs. For the migration guide to MSP430FR57xx, see Migrating From the MSP430F2xx Family to the MSP430FR57xx Family. It covers programming, system, and peripheral considerations when migrating firmware. The intent is to highlight key differences between the two fGeneral Oversampling of MSP ADCs for Higher Resolution (Rev. A)PDF, 551 Кб, Версия: A, Файл опубликован: 1 апр 2016
 Multiple MSP ultra-low-power microcontrollers offer analog-to-digital converters (ADCs) to convert physical quantities into digital numbers, a function that is widely used across numerous applications. There are times, however, when a customer design demands a higher resolution than the ADC of the selected MSP can offer. This application report, which is based on the previously-published OversamplМодельный рядСерия: MSP430FR5857 (4)- MSP430FR5857IDA MSP430FR5857IDAR MSP430FR5857IRHAR MSP430FR5857IRHAT
 Классификация производителя- Semiconductors > Microcontrollers (MCU) > MSP430 ultra-low-power MCUs > MSP430FRxx FRAM
 На английском языке: Datasheet Texas Instruments MSP430FR5857IRHAR
