Datasheet Texas Instruments MSP430F5328TRGCTEP — Даташит
СерияMSP430F5328-EP
МодельMSP430F5328TRGCTEP
Микроконтроллер смешанных сигналов, MSP430F5328-EP 64-VQFN от -40 до 105
Mixed Signal Microcontroller, MSP430F5328-EP datasheet
PDF, 1.3 Мб, Файл опубликован: 26 дек 2013
13 предложений от 10 поставщиков
IC MCU 16BIT 128KB FLASH 64VQFN. CPUXV2 MSP430F5xx Microcontroller IC 16-Bit 25MHz 128KB (128K x 8) FLASH 64-VQFN (9x9). Embedded -...
MSP430F5328TRGCTEP
248 ₽
MSP430F5328TRGCTEP
963 ₽
MSP430F5328TRGCTEP
от 992 ₽
727GS
MSP430F5328TRGCTEP
Pin64
Package TypeRGC
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаM4F5328T
Width (мм)9
Length (мм)9
Thickness (мм).88
Pitch (мм).5
Max Height (мм)1
ADCADC12 - 10ch
AESN/A
Active Power404 uA/MHz
Additional FeaturesReal-Time Clock,Watchdog,Temp Sensor,Brown Out Reset,IrDA
BSLUART
CPUMSP430
ComparatorsYes
DMA3
Тактовая частота25 МГц
GPIO48
I2C2
Max VCC3.6
Min VCC1.8
Multiplier32x32
Non-volatile Memory128 KB
Package GroupVQFN
Package Size: mm2:W x L64VQFN: 81 mm2: 9 x 9(VQFN) PKG
RAM10 KB
RatingHiRel Enhanced Product
SPI2
Special I/ON/A
Standby Power2.5 LPM3-uA
Timers - 16-bit4
UART2
Wakeup Time3.5 us
  • Evaluation Modules & Boards: MSP-FET430U64B
    64-pin Target Development Board and MSP-FET Programmer Bundle for MSP430F5x MCUs
    MSP EnergyTrace Technology
  • Using the MSP430 Timer_D Module in Hi-Resolution Mode
    PDF, 870 Кб, Файл опубликован: 2 окт 2013
    This application report describes the use of the high-resolution feature of the Timer_D module introduced in MSP430F51x1 and MSP430F51x2 devices. Timer_D enables applications that require high resolution such as capacitive touch detection, PWM DACs, advanced LED lighting, and digital controllers for power supplies. This application report provides an advanced description of the use and calibration
  • General Oversampling of MSP ADCs for Higher Resolution (Rev. A)
    PDF, 551 Кб, Версия: A, Файл опубликован: 1 апр 2016
    Multiple MSP ultra-low-power microcontrollers offer analog-to-digital converters (ADCs) to convert physical quantities into digital numbers, a function that is widely used across numerous applications. There are times, however, when a customer design demands a higher resolution than the ADC of the selected MSP can offer. This application report, which is based on the previously-published Oversampl
Серия: MSP430F5328-EP (2)
  • Semiconductors > Space & High Reliability > Microcontroller > Low Power MCU > MSP430 MCU
На английском языке: Datasheet Texas Instruments MSP430F5328TRGCTEP
Публикации по теме
