Datasheet Texas Instruments TPA3110D2QPWPRQ1 — Даташит
Серия | TPA3110D2-Q1 |
Модель | TPA3110D2QPWPRQ1 |
Автомобильный стереоусилитель класса D без фильтров, 15 Вт, с поддержкой SpeedGuardT 28-HTSSOP от -40 до 125
TPA3110D2-Q1 15-W Filter-Free Stereo Class-D Audio Power Amplifier With SpeakerGuardв„ў datasheet
PDF, 1.8 Мб, Версия: B, Файл опубликован: 9 сен 2015
![]() 30 предложений от 15 поставщиков Микросхема Усилитель звуковой частоты, Audio Amp Speaker 2CH Stereo 15W Class-D 28Pin HTSSOP T/R | |||
TPA3110D2QPWPRQ1 Texas Instruments | 44 ₽ | ||
TPA3110D2QPWPRQ1 Texas Instruments | от 129 ₽ | ||
TPA3110D2QPWPRQ1 Texas Instruments | 295 ₽ | ||
TPA3110D2QPWPRQ1 Texas Instruments | по запросу |
Pin | 28 |
Package Type | PWP |
Industry STD Term | HTSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | TPA3110Q1 |
Width (мм) | 4.4 |
Length (мм) | 9.7 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Analog Supply (V) | 26 Min |
Audio Input Type | Analog |
Closed/Open Loop | Closed |
Control Interface | Hardware |
Package Group | HTSSOP |
Package Size: mm2:W x L | 28HTSSOP: 62 mm2: 6.4 x 9.7(HTSSOP) PKG |
Power Stage Supply(Max) | 26 В |
Power Stage Supply(Min) | 8 В |
Power to Bridge Tied Load(Max) | 15 W |
Rating | Automotive |
Speaker Channels | 2 Max |
Supported Bridge Tied Load(Min) | 4 Ohms |
- Evaluation Modules & Boards: TPA3110D2EVM
TPA3110D2 Evaluation Module
- Short-to-Battery Protection Strategies for Class-D AmplifiersPDF, 3.2 Мб, Файл опубликован: 11 ноя 2016
This document introduces the potential faults that can occur in class-D amplifier solutions, and describes how most faults are intrinsically protected for and how to extend coverage to protect against all short-circuit faults. Of particular focus is the case when an output is shorted to a battery voltage higher than the device supply voltage. This fault allows the parasitic body diode found in the - AN-1737 Managing EMI in Class D Audio Applications (Rev. A)PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit. - Using Thermal Calculation Tools for Analog ComponentsPDF, 1.1 Мб, Файл опубликован: 2 сен 2010
This document provides general guidance on the use of toolsand calculations for thermal estimates of component operating temperatures for analog devices. Of particularfocus are components with direct thermal paths to the PCB which is common for components which need a low thermal resistance to manage the dissipated power. This document provides practical considerations for estimation of o - AN-1849 An Audio Amplifier Power Supply Design (Rev. B)PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs. - Guidelines for Measuring Audio Power Amplifier PerformancePDF, 765 Кб, Файл опубликован: 30 окт 2001
This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TPA3110D2-Q1 (1)
- TPA3110D2QPWPRQ1
- Semiconductors > Audio > Mid-Power Audio Amplifiers (10-50W) > Analog Input Amplifiers
