Datasheet Texas Instruments TPS6734IP — Даташит
СерияTPS6734
МодельTPS6734IP
Фиксированный источник питания повышающего преобразователя 12 В, 120 мА, 8-PDIP от -40 до 85
Fixed 12-V 120-mA Boost-Converter Supply datasheet
PDF, 479 Кб, Версия: A, Файл опубликован: 19 янв 1999
Package TypeP
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY50
Width (мм)6.35
Length (мм)9.81
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
  • Evaluation Modules & Boards: TPS6734EVM
    12V; 120mA Output Boost Converter with 3.75V to 12V input EVM
  • Providing a DSP Power Solution From 5-V Or A 3.3-V Only System
    PDF, 59 Кб, Файл опубликован: 26 май 1999
    The TPS56xx family of switching regulator controllers is designed to provide low voltages at high currents to today's digital signal processors such as the C5000 and C6000 families from TI as well as simliar digital loads. The TPS56xx uses a 12-V power supply to optimize the circuitry and provide the excellent transient response required in these demanding systems. The TPS6734 controller can be u
  • Understanding Buck Power Stages In Switchmode Power Supplies
    PDF, 173 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the buck power stage only and does not cover control circuits. Detailed steady-state and small-signal analysis of the buck power stage operating in continuous
  • Understanding Boost Power Stages In Switchmode Power Supplies
    PDF, 149 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the boost power stage only and does not cover control circuits. The report includes detailed steady-stage and small-signal analysis of the boost power stage o
  • Understanding Buck-Boost Power Stages in Switchmode Power Supplies (Rev. A)
    PDF, 363 Кб, Версия: A, Файл опубликован: 28 май 2002
Серия: TPS6734 (6)
  • Semiconductors > Power Management > DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments TPS6734IP
