Datasheet Texas Instruments OMAPL138EZWT3 — Даташит
СерияOMAP-L138
МодельOMAPL138EZWT3
C6000 DSP+ARM процессор 361-NFBGA от 0 до 90
OMAP-L138 C6000 DSP+ARM Processor datasheet
PDF, 2.0 Мб, Версия: J, Файл опубликован: 31 янв 2017
Pin361361361
Package TypeZWTZWTZWT
Industry STD TermNFBGANFBGANFBGA
JEDEC CodeS-PBGA-NS-PBGA-NS-PBGA-N
Package QTY909090
CarrierJEDEC TRAY (5+1)JEDEC TRAY (5+1)JEDEC TRAY (5+1)
МаркировкаOMAPL138EZWT375
Width (мм)161616
Length (мм)161616
Thickness (мм).9.9.9
Pitch (мм).8.8.8
Max Height (мм)1.41.41.4
ARM CPU1 ARM9
ARM MHz456 Max.
ApplicationsCommunications and Telecom,Consumer Electronics,Energy,Industrial,Medical
DRAMLPDDR,DDR2
DSP1 C674x
DSP MHz456 Max.
Display Options1
EMAC10/100
I2C2
On-Chip L2 Cache256 KB (DSP)
Operating SystemsLinux,SYS/BIOS
Рабочий диапазон температурот -40 до 105,-40 до 90,0 до 90 C
Other On-Chip Memory128 KB
SATA1
SPI2
UART3 SCI
USB2
Video Port1 Configurable
  • Development Kits: TMDSLCDK138
    OMAP-L138 Development Kit (LCDK)
  • Development Kits: TMDSLCDK6748
    TMS320C6748 DSP Development Kit (LCDK)
    XDS200 USB Debug Probe
  • Using the OMAP-L132/L138 Bootloader Application Report (Rev. E)
    PDF, 1.6 Мб, Версия: E, Файл опубликован: 23 янв 2014
    This application report describes various boot mechanisms supported by the OMAP-L132/138 bootloader read-only memory (ROM) image. Topics covered include the Application Image Script (AIS) boot process, an AISgen tool used to generate boot scripts, protocol for booting the device from an external master device, a UART Boot Host GUI for booting the device from a host PC, and any limitations, default
  • OMAP-L132/L138 Power Consumption Summary
    PDF, 37 Кб, Файл опубликован: 30 авг 2010
    This article discusses the power consumption of the Texas Instruments OMAP-L138. Power consumption on the OMAP-L138 devices are highly application-dependent. The low-core voltage and other power design optimizations allow these devices to operate with industry-leading performance, while maintaining a low power-to-performance ratio.The power data presented in this document are based on measu
  • Powering the OMAP-L132/OMAP-L137/OMAP-L138 Processor with the TPS650061
    PDF, 695 Кб, Файл опубликован: 13 апр 2012
    TPS650061, OMAP-L132, OMAP-L137, OMAP-L138 Power Sequencing for OMAP-L132, L137, and L138 using the TPS650061
  • SGI EVM Software Manual
    PDF, 28 Кб, Файл опубликован: 27 июн 2012
    This article will guide you in the basic setup of the file system and Linux kernel for the Smart Grid Infrastructure (SGI) EVM. It also provides information on modifying and rebuilding the Linux kernel for your application.The SGI platform is designed for development and test of smart grid applications including: data concentrator, power protection and monitoring, power analytics, industria
  • Running the Metrology Demo on the SGI EVM
    The Metrology Demo showcases the ability of the dual-core OMAP-L138 DSP+ARM processor to execute metrology functions, power analytics algorithms (FFT), and a Rogowski coil digital integrator on its TMS320C674x DSP, while at the same time running a high-level operating system (Linux) with network communication on its ARM9в„ў core. A Windows PC graphical user interface (GUI) is used to display t
  • TMS320C674x/OMAP-L1x Processor Security
    PDF, 29 Кб, Файл опубликован: 8 июн 2011
    The generic secure environment is supported by hardware within the C674x DSP core. This allows critical code to be executed in a secure environment, hiding sensitive information from the outside world with the help of the following hardware features:Secure thread support – hardware support that allows trusted code to be executed from secure ROMor secure RAM.Protected transition
  • WiLink 6.0 (WL1271) OpenLink Platform (Rev. A)
    PDF, 735 Кб, Версия: A, Файл опубликован: 26 апр 2011
  • OMAP-L1x8 Complementary Products
    PDF, 26 Кб, Файл опубликован: 20 июл 2009
    This article has been contributed to the TI DaVinciв„ў and OMAPв„ў Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://tiexpressdsp.com/index.php/OMAP-L1x8_Complementary_Products .This Wiki article serves as a repository of complimentary devices that ca
  • Powering OMAP-L132/L138, C6742/4/6, and AM18x with TPS65070 (Rev. B)
    PDF, 453 Кб, Версия: B, Файл опубликован: 29 авг 2011
    This documents details the design consideration of a power management unit (PMU) solution for the OMAP-L132/-L138 low-power applications processors with a TPS65070 five-channel power management device.
  • OMAP-L132/L138, TMS320C6742/6/8 Pin Multiplexing Utility (Rev. B)
    PDF, 37 Кб, Версия: B, Файл опубликован: 27 сен 2013
    The OMAP-L1x8 and C6742/6/8 devices use a great deal of internal pin multiplexing to allow the most functionality in the smallest and lowest cost package. This software allows the pin multiplexing registers of the device to be calculated with ease, as well as showing what peripherals can be used together and what devices support the peripherals that are selected. This software is useful to anyone
  • Canny Edge Detection Implementation on TMS320C64x/64x+ Using VLIB
    PDF, 97 Кб, Файл опубликован: 25 ноя 2009
    This application note contains instructions for implementing Canny Edge Detection algorithm using VLIB. The general ideas given here can also be applied for an application which calls a sequence of VLIB functions in a block-based manner.
  • High-Vin, High-Efficiency Power Solution Using DC/DC Converter With DVFS (Rev. C)
    PDF, 266 Кб, Версия: C, Файл опубликован: 29 авг 2011
    This reference design is intended for users designing with the TMS320C6742, TMS320C6746, TMS320C6748, or OMAP-L132/L138 processor. Using sequenced power supplies, this reference design describes a system having a 12-V input voltage and a high-efficiency dc/dc converter with integrated FETs and dynamic voltage and frequency scaling (DVFS) for a small, simple design.Sequenced power supply architec
  • Simple Power Solution Using LDOs (Rev. B)
    PDF, 150 Кб, Версия: B, Файл опубликован: 29 авг 2011
    This reference design helps those desiring to design-in the TMS320C6742, TMS320C6746, TMS320C6748, and OMAP-L132/L138. This design, employing sequenced power supplies, describes asystem with an input voltage of 3.3 V, and uses LDOs for a small, simple system.Sequenced power supply architectures are becoming commonplace in high-performance microprocessor and digital signal processor (DSP) syste
  • Medium Integrated Power Solution Using a Dual DC/DC Converter and an LDO (Rev. B)
    PDF, 387 Кб, Версия: B, Файл опубликован: 29 авг 2011
    This reference design is intended for users designing with the TMS320C6742, TMS320C6746, TMS320C6748, or OMAP-L132/L138 processor. Using sequenced power supplies, this reference design describes a system having a 3.3-V input voltage and a high-efficiency dc/dc converter with integrated FETs for a small, simple design.Sequenced power supply architectures are becoming commonplace in high-performan
  • High-Integration, High-Efficiency Power Solution Using DC/DC Converters w/DVFS (Rev. A)
    PDF, 208 Кб, Версия: A, Файл опубликован: 5 май 2010
    This reference design is intended for users designing with the TMS320C6742, TMS320C6746, TMS320C6748, OMAP-L138 or AM18x processor. Using sequenced power supplies, this reference design describes a system having a 12-V input voltage and a high-efficiency dc/dc converter with ntegrated FETs and dynamic voltage and frequency scaling (DVFS) for a small, simple design.Sequenced power supply archit
  • High-Efficiency Power Solution Using DC/DC Converters With DVFS (Rev. A)
    PDF, 161 Кб, Версия: A, Файл опубликован: 5 май 2010
  • TMS320C6748/46/42 & OMAP-L132/L138 USB Downstream Host Compliance Testing
    PDF, 3.6 Мб, Файл опубликован: 17 авг 2009
    This application report describes the TMS320C6748/46/42 and OMAP-L1x8 embedded Host electrical compliance of a high-speed (HS) universal serial bus (USB) operation conforming to the USB 2.0 specification. The OTG controller supports the USB 2.0 device and host mode at high-speed (HS), full-speed (FS) and low-speed (LS).
  • TMS320C6748/46/42 & OMAP-L1x8 USB Upstream Device Compliance Testing
    PDF, 1.1 Мб, Файл опубликован: 17 авг 2009
    This application report describes the TMS320C6748/46/42 and OMAP-L1x8 electrical compliance of a high-speed (HS) universal serial bus (USB) operation conforming to the USB 2.0 specification. The on-the-go (OTG) controller supports the USB 2.0 device and host mode at high-speed (HS), full-speed (FS) and low-speed (LS).
  • TMS320C674x/OMAP-L1x USB Compliance Checklist
    PDF, 89 Кб, Файл опубликован: 12 мар 2009
    This application report contains the USB checklist for the TMS320C674x/OMAP-L1x (C674x/OMAP-L1x). The C674x/OMAP-L1x has a compliant full-speed USB device port and does not support a low-speed USB device operation.
  • OMAP-L1x/C674x/AM1x SOC Architecture and Throughput Overview
    PDF, 19 Кб, Файл опубликован: 12 фев 2010
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://wiki.davincidsp.com/index.php/OMAP-L1x/C674x/AM1x_SOC_Architecture_and_Throughput_Overview. This collection of Wiki articles provide i
  • TI DSP Benchmarking
    PDF, 62 Кб, Файл опубликован: 13 янв 2016
    This application report provides benchmarks for the C674x DSP core, the C66x DSP core and the ARMВ®CortexВ®-A15 core. This document also shows how to reproduce these benchmarks on specific hardware platforms.
  • Understanding TI's PCB Routing Rule-Based DDR Timing Specification (Rev. A)
    PDF, 93 Кб, Версия: A, Файл опубликован: 17 июл 2008
    This application report motivates the way the DDR high-speed timing requirements are now going to be communicated to system designers. The traditional method of using data sheet parameters and simulation models is tedious. The system designer uses this information to evaluate whether timing specifications are met and can be expected to operate reliably.Ultimately, the real question the hardwa
  • High-Speed Interface Layout Guidelines (Rev. G)
    PDF, 814 Кб, Версия: G, Файл опубликован: 27 июл 2017
    As modern bus interface frequencies scale higher, care must be taken in the printed circuit board (PCB) layout phase of a design to ensure a robust solution.
  • Semiconductors > Processors > Digital Signal Processors > C6000 DSP + ARM Processors > OMAP-L1x
На английском языке: Datasheet Texas Instruments OMAPL138EZWT3
