Линейка продуктов KEEN SIDE
Datasheet Texas Instruments UCC38501DW — Даташит
СерияUCC38501
МодельUCC38501DW
Комбинированный контроллер BiCMOS PFC/PWM 20-SOIC от 0 до 70
BiCMOS PFC/PWM Combination Controller datasheet
PDF, 1.1 Мб, Версия: C, Файл опубликован: 8 ноя 2001
Pin20
Package TypeDW
Package QTY25
МаркировкаUCC38501DW
Width (мм)7.5
Length (мм)12.8
Thickness (мм)2.35
Max Height (мм)2.65
Control MethodCCM
Device TypePFC+PWM
Operating Supply Current4 мА
Operating Supply(Max)18 В
Package Size: mm2:W x L20SOIC: 132 mm2: 10.3 x 12.8(SOIC) PKG
Peak Output Sink Current Gate Drive1.2 A
Peak Output Source Current Gate Drive-1.2 A
Practical Operating Frequency(Max)0.2 МГц
Special Features< 150W Applications,Average Current Mode,Enable,OVP
Startup Current0.15 мА
UVLO Thresholds On/Off10.5/10 В
  • Evaluation Modules & Boards: UCC38500EVM
    UCC38500EVM Evaluation Module
  • Bootstrap Circuit for Green Mode Applications
    PDF, 111 Кб, Файл опубликован: 27 янв 2006
  • A New Synchronization Circuit for Power Converters (Rev. A)
    PDF, 209 Кб, Версия: A, Файл опубликован: 21 апр 2010
    The synchronization of multiple PWM and PFC controllers is desirable for many reasons. The most common reason is that it keeps all the noise at one particular frequency and makes it easier to filter. The circuit described changes the slope of the ramp to lock the converter’s switching frequency to an applied signal by a phase locked loop turning it into a voltage controlled oscillator. Furthermore
  • Startup Current transient of the Leading Edge Triggered PFC Controllers
    PDF, 43 Кб, Файл опубликован: 30 июн 2004
  • Avoiding Audible Noise at Light Loads When Using Leading Edge Triggered PFC Con (Rev. C)
    PDF, 57 Кб, Версия: C, Файл опубликован: 13 апр 2011
    This application note applies to the TI average current mode, leading edge modulation PFC controllers. See Applicable Device Table for part numbers.
  • DN-66 UC3854A/B and UC3855A/B Provide Power Limiting with Sinusoidal Input (Rev. A)
    PDF, 80 Кб, Версия: A, Файл опубликован: 6 ноя 2001
  • Accurate PWM Duty Cycle Clamp
    PDF, 58 Кб, Файл опубликован: 25 янв 2002
    Power supply applications using current sense transformers require a duty cycle clamp on the pulse width modulator (PWM) to ensure transformer reset. Not all PWMs come with a duty cycle clamp presenting a problem for the power supply designer. This application note shows how to implement a duty cycle clamp by using a simple delay circuit.
Серия: UCC38501 (5)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Power Factor Correction
На английском языке: Datasheet Texas Instruments UCC38501DW
