Datasheet Texas Instruments 5962-8768101QFA — Даташит
СерияUC1825
Модель5962-8768101QFA
Высокоскоростной ШИМ-контроллер 16-CFP от -55 до 125
High Speed PWM Controller datasheet
PDF, 2.1 Мб, Версия: A, Файл опубликован: 24 фев 2004
Pin16
Package TypeW
Industry STD TermCFP
JEDEC CodeR-GDFP-F
Package QTY1
Width (мм)6.73
Length (мм)10.3
Thickness (мм)1.65
Max Height (мм)2.03
Control MethodCurrent
Duty Cycle(Max)80 %
Основные особенностиError Amplifier,Soft Start,Synchronization Pin,Multi-topology
Frequency(Max)1000 kHz
Frequency(Min)0.1 kHz
Package GroupCFP
Package Size: mm2:W x LSee datasheet (CFP) PKG
RatingMilitary
TopologyBoost,Flyback,Forward,Full-Bridge,Half-Bridge,Push-Pull
UVLO Thresholds On/Off9.2/8.4 В
Vin(Max)30 В
Vin(Min)8.4 В
RoHSSee ti.com
  • U-110 1.5 Mhz Current Mode IC Controlled 50-Watt Power Supply
    PDF, 298 Кб, Файл опубликован: 5 сен 1999
    The UC3825 family of PWM control ICs is optimized for high-frequency switched-mode power-supply applications. This application note describes the development of a 1.5 MHz current-mode IC-controlled 50W power supply. Push-pull topology is used for this DC-to-DC converter application of +48V input to +5V at 10A output. Increases in switching speed and dynamic performance are made possible by the U
  • U-111 Practical Considerations in Current Mode Power Supplies
    PDF, 787 Кб, Файл опубликован: 5 сен 1999
    This application note explains the numerous PWM functions and ways to maximize their usefulness. It covers practical circuit design considerations such as slope compensation gate drive circuitry external control functions synchronization and paralleling current-mode controlled modules. Circuit diagrams and simplified equations are included.
  • Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
59628768101QFA, 5962 8768101QFA
На английском языке: Datasheet Texas Instruments 5962-8768101QFA
