Datasheet Texas Instruments OPA379AIDCKRG4 — Даташит
СерияOPA379
МодельOPA379AIDCKRG4
1,8 В, 2,9 мкА, 90 кГц Операционный усилитель ввода-вывода Rail-to-Rail 5-SC70 от -40 до 125
1.8V, 2.9µA, 90kHz, Rail-to-Rail I/O Operational Amplifiers datasheet
PDF, 1.5 Мб, Версия: D, Файл опубликован: 8 янв 2007
Pin5
Package TypeDCK
Industry STD TermSOT-SC70
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
Additional FeaturesEMI Hardened
Approx. Price (US$)0.40 | 1ku
АрхитектураCMOS
CMRR(Min)(dB)90
CMRR(Typ)(dB)100
GBW(Typ)(MHz)0.09
Input Bias Current(Max)(pA)50
Iq per channel(Max)(mA)0.0055
Iq per channel(Typ)(mA)0.0029
Number of Channels(#)1
Offset Drift(Typ)(uV/C)2.7
Operating Temperature Range(C)-40 to 125
Output Current(Typ)(mA)5
Package GroupSC70
Package Size: mm2:W x L (PKG)5SC70: 4 mm2: 2.1 x 2(SC70)
Rail-to-RailIn
Out
Slew Rate(Typ)(V/us)0.03
Total Supply Voltage(Max)(+5V=5, +/-5V=10)5.5
Total Supply Voltage(Min)(+5V=5, +/-5V=10)1.8
Vn at 1kHz(Typ)(nV/rtHz)80
Vos (Offset Voltage @ 25C)(Max)(mV)1.5
RoHSНе совместим
  • Supplying TPS61200 With a Single Solar Cell (Rev. B)
    PDF, 129 Кб, Версия: B, Файл опубликован: 6 сен 2011
    This application report explains how to use the TPS61200 in combination with a single solar cell to charge a battery or storage device. A characteristic of solar cells is the internal resistance that can vary from less than 10 Ω up to more than 100 Ω. Therefore it is important to control the load placed on the solar cell to ensure a reliable start-up of the application. This report describes an a
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
  • Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Ultra-Low-Power Op Amps (<=250uA)
На английском языке: Datasheet Texas Instruments OPA379AIDCKRG4
