Линейка продуктов KEEN SIDE
Datasheet Texas Instruments TMS320DM8167SCYG4 — Даташит
СерияTMS320DM8167
МодельTMS320DM8167SCYG4
Цифровой медиапроцессор DaVinci 1031-FCBGA от 0 до 95
TMS320DM816x DaVinci Digital Media Processors datasheet
PDF, 2.6 Мб, Версия: F, Файл опубликован: 17 мар 2015
Pin103110311031
Package TypeCYGCYGCYG
Industry STD TermFCBGAFCBGAFCBGA
JEDEC CodeS-PBGA-NS-PBGA-NS-PBGA-N
Package QTY444444
CarrierJEDEC TRAY (5+1)JEDEC TRAY (5+1)JEDEC TRAY (5+1)
Маркировка4TMS320DM8167SCYG
Width (мм)252525
Length (мм)252525
Thickness (мм)2.812.812.81
Pitch (мм).65.65.65
Max Height (мм)3.313.313.31
ARM CPU1 ARM Cortex-A8
ARM MHz1200 Max.
ApplicationsVideo Security
DRAMDDR2,DDR3
DSP1 C674x
DSP MHz1000 Max.
EMAC2x 10/100/1000
I2C2
On-Chip L2 Cache256 KB (ARM Cortex-A8),256 KB (DSP)
Operating SystemsLinux,Android,DSP/BIOS
Рабочий диапазон температурот 0 до 95 C
PCI/PCIe2 PCIe Gen2
Pin/Package1031FCBGA
SPI1
UART3 SCI
USB2
Video Acceleration3 HDVICPs
Video Port1 HDMI TX,2 Input,2 Output,3 HD DACs,4 SD DACs Configurable
Video Resolution/Frame Rate1080p,60 FPS or less
  • Development Kits: TMDXEVM8168
    DM816x/AM389x Evaluation Module
    XDS200 USB Debug Probe
  • DM816x, C6A816x, and AM389x Overview
    PDF, 29 Кб, Файл опубликован: 7 июл 2011
    This article provides an overview of the DM816x, C6A816x, and AM389x product families and has been contributed to the TI Embedded Processors Wiki. To see the most recently updated version or to contribute, visit this topic at:http://processors.wiki.ti.com/index.php/DM816x_C6A816x_AM389x_OverviewAll t
  • TMS320DM816x/C6A816x/AM389x DDR3 Initialization With Software Leveling
    PDF, 21 Кб, Файл опубликован: 1 мар 2011
    This article has been contributed to the TI Embedded Processors Wiki. The article describes how to initialize the DDR3 on the TMS320DM816x DaVinciв„ў digital media processors, TMS320C6A816x Integraв„ў DSP+ ARMВ® processors, and AM389x Sitaraв„ў ARMВ® microprocessors (MPUs) PG1.1 samples using the software leveling process.To see the most recently updated version or to cont
  • PCIe to USB on the TMS320DM816x/TMS320C6A816x/AM389x Evaluation Board
    PDF, 22 Кб, Файл опубликован: 1 мар 2011
    This article has been contributed to the TI Embedded Processors Wiki. The article describes using the PCI ExpressВ® ( PCIeВ®) to the USB host controller card on the TMS320DM816x DaVinciв„ў digital media processors, TMS320C6A816x Integraв„ў DSP+ ARMВ® processors, and AM389x Sitaraв„ў ARMВ® microprocessors (MPUs) family of devices running Linux kernel from a PSP package. This
  • TMS320DM816x/TMS320C6A816x/AM389x Power Estimation Spreadsheet
    PDF, 30 Кб, Файл опубликован: 18 май 2011
    This article has been contributed to the TI Embedded Processors Wiki. It describes how to model power consumption for a user's application and to present some measured power scenarios for the TMS320DM816x DaVinciв„ў digital media processors, TMS320C6A816x C6-Integraв„ў DSP+ARM processors, and AM389x Sitaraв„ў ARMВ® microprocessors (MPUs) PG1.0 samples using a provided power estimati
  • DM816xx Easy CYG Package PCB Escape Routing (Rev. A)
    PDF, 675 Кб, Версия: A, Файл опубликован: 19 мар 2015
    The DM816x CYG package is designed with a new technology called a Via Channelв„ў array. This technology allows for easy routing of the device in two signal and two power layers using large throughhole via diameters and standard trace widths; it is cost and time effective. Where more than four printed circuit board (PCB) layers are used, the routing is much more open and flexible than a regular
  • High-Speed Interface Layout Guidelines (Rev. G)
    PDF, 814 Кб, Версия: G, Файл опубликован: 27 июл 2017
    As modern bus interface frequencies scale higher, care must be taken in the printed circuit board (PCB) layout phase of a design to ensure a robust solution.
Серия: TMS320DM8167 (3)
  • Semiconductors > Processors > Digital Signal Processors > Media Processors > Digital Video Processors
На английском языке: Datasheet Texas Instruments TMS320DM8167SCYG4
