Заказные клавиатуры Accord по вашему ТЗ
Datasheet ТI SN74LVC16244ADLRG4 — Даташит
СерияSN74LVC16244A
МодельSN74LVC16244ADLRG4
Datasheet Texas Instruments SN74LVC16244ADLRG4
16-битный буфер/драйвер с выходами с 3 состояниями 48-SSOP от -40 до 125
SN74LVC16244A 16-Bit Buffer/Driver With 3-State Outputs datasheet
PDF, 1.0 Мб, Версия: C, Файл опубликован: 28 янв 2014
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
На английском языке: Datasheet Texas Instruments SN74LVC16244ADLRG4
Политика конфиденциальности
