Оптопары и оптореле Megawin
Datasheet Texas Instruments OPA379AIDCKT — Даташит
СерияOPA379
МодельOPA379AIDCKT
1,8 В, 2,9 мкА, 90 кГц Операционный усилитель ввода-вывода Rail-to-Rail 5-SC70 от -40 до 125
1.8V, 2.9µA, 90kHz, Rail-to-Rail I/O Operational Amplifiers datasheet
PDF, 1.5 Мб, Версия: D, Файл опубликован: 8 янв 2007
Pin5
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY250
CarrierSMALL T&R
МаркировкаB54
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
Additional FeaturesEMI Hardened
АрхитектураCMOS
CMRR(Min)90 дБ
CMRR(Typ)100 дБ
GBW(Typ)0.09 МГц
Input Bias Current(Max)50 pA
Iq per channel(Max)0.0055 мА
Iq per channel(Typ)0.0029 мА
Количество каналов1
Offset Drift(Typ)2.7 uV/C
Output Current(Typ)5 мА
Package GroupSC70
Package Size: mm2:W x L5SC70: 4 mm2: 2.1 x 2(SC70) PKG
Rail-to-RailIn,Out
Slew Rate(Typ)0.03 V/us
Total Supply Voltage(Max)5.5 +5V=5, +/-5V=10
Total Supply Voltage(Min)1.8 +5V=5, +/-5V=10
Vn at 1kHz(Typ)80 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)1.5 мВ
  • Supplying TPS61200 With a Single Solar Cell (Rev. B)
    PDF, 129 Кб, Версия: B, Файл опубликован: 6 сен 2011
    This application report explains how to use the TPS61200 in combination with a single solar cell to charge a battery or storage device. A characteristic of solar cells is the internal resistance that can vary from less than 10 Ω up to more than 100 Ω. Therefore it is important to control the load placed on the solar cell to ensure a reliable start-up of the application. This report describes an a
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
  • Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Ultra-Low-Power Op Amps (<=10uA)
На английском языке: Datasheet Texas Instruments OPA379AIDCKT
