Datasheet Texas Instruments UCC28528DW — Даташит
СерияUCC28528
МодельUCC28528DW
Усовершенствованный комбинированный контроллер PWM/PFC с модуляцией TEM/TEM 20-SOIC от -40 до 105
Advanced PFC/PWM Combination Controller w/Trailing-Edge/Trailing-Edge Modulation datasheet
PDF, 781 Кб, Версия: D, Файл опубликован: 15 ноя 2005
Pin20
Package TypeDW
Package QTY25
МаркировкаUCC28528DW
Width (мм)7.5
Length (мм)12.8
Thickness (мм)2.35
Max Height (мм)2.65
Control MethodCCM
Device TypePFC+PWM
Operating Supply Current4 мА
Operating Supply(Max)18 В
Package Size: mm2:W x L20SOIC: 132 mm2: 10.3 x 12.8(SOIC) PKG
Peak Output Sink Current Gate Drive3.5 A
Peak Output Source Current Gate Drive-2.5 A
Practical Operating Frequency(Max)0.5 МГц
Special Features< 150W Applications,> 750W Applications,Average Current Mode,Enable,OVP
Startup Current0.1 мА
UVLO Thresholds On/Off10.2/9.7 В
  • Evaluation Modules & Boards: UCC28528EVM
    UCC28528 Evaluation Module
  • Evaluation Modules & Boards: UCC28521EVM
    UCC28521 Evaluation Module
  • 350-W, Two Phase Interleaved PFC Pre-Regulator (Rev. C)
    PDF, 424 Кб, Версия: C, Файл опубликован: 20 сен 2013
  • UCC28517 100-W PFC power converter with 12-V, 8-W bias supply, Part 2
    PDF, 224 Кб, Файл опубликован: 28 фев 2005
    To conclude the review of the UCC28517 PFC supply, this article covers the design of the second 12-V, 8-W power stage to be used as an auxiliary bias supply.
  • UCC28517 100-W PFC power converter with 12-V, 8-W bias supply, Part 1
    PDF, 202 Кб, Файл опубликован: 28 фев 2005
    Power factor corrected (PFC) preregulators are generally used in ac/dc converters operating above 75 W or to meet line harmonic requirements. This article reviews the design of a 100-W ac/dc power stage with PFC.
  • A New Synchronization Circuit for Power Converters (Rev. A)
    PDF, 209 Кб, Версия: A, Файл опубликован: 21 апр 2010
    The synchronization of multiple PWM and PFC controllers is desirable for many reasons. The most common reason is that it keeps all the noise at one particular frequency and makes it easier to filter. The circuit described changes the slope of the ramp to lock the converter’s switching frequency to an applied signal by a phase locked loop turning it into a voltage controlled oscillator. Furthermore
Серия: UCC28528 (3)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Power Factor Correction
На английском языке: Datasheet Texas Instruments UCC28528DW
