Datasheet Texas Instruments LM3435SQ/NOPB — Даташит
СерияLM3435
МодельLM3435SQ/NOPB
Компактный драйвер RGB-светодиода последовательного режима с интерфейсом управления IC 40-WQFN от -40 до 125
LM3435 Compact Sequential Mode RGB LED Driver with I 2 C Control Interface datasheet
PDF, 1.7 Мб, Версия: C, Файл опубликован: 2 май 2013
Pin40
Package TypeRSB
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY1000
МаркировкаL3435SQ
Width (мм)5
Length (мм)5
Thickness (мм).75
Pitch (мм).4
Max Height (мм).8
Dimming MethodIndividual RGB PWM
Входное напряжениеDC/DC Type
Iout(Max)2 A
Iq(Typ)5 мА
Package GroupWQFN
Package Size: mm2:W x L40WQFN: 25 mm2: 5 x 5(WQFN) PKG
Power Factor CorrectionN/A Min
Regulated Outputs3
Special FeaturesAdjustable Switch Frequency,Enable/Shutdown,Integrated Switch,Soft Start,Thermal Shutdown
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)100 kHz
TopologyBuck-Boost
ТипInductive,Linear
Vin(Max)5.5 В
Vin(Min)2.7 В
Vout(Max)4.7 В
Vout(Min)1.5 В
Vref1.24 В
  • Evaluation Modules & Boards: LM3435EVAL
    Pico Projector LED Driver Evaluation Board
  • AN-1656 Design Challenges of Switching LED Drivers (Rev. A)
    PDF, 171 Кб, Версия: A, Файл опубликован: 3 май 2013
    Using a switching regulator as an LED driver requires the designer to convert a voltage regulator into acurrent regulator. Beyond the challenge of changing the feedback system to control current, the LEDsthemselves present a load characteristic that is much different than the digital devices and other loads thatrequire constant voltage. The LED WEBENCHВ® online design environment predicts and
Серия: LM3435 (2)
  • Semiconductors > Power Management > LED Driver > Illumination & General Lighting LED Driver
На английском языке: Datasheet Texas Instruments LM3435SQ/NOPB
