Datasheet Texas Instruments UC2825QTR — Даташит
СерияUC2825
МодельUC2825QTR
Высокоскоростной ШИМ-контроллер 20-PLCC от -40 до 85
High Speed PWM Controller datasheet
PDF, 1.2 Мб, Версия: A, Файл опубликован: 24 фев 2004
Pin20
Package TypeFN
Industry STD TermPLCC
JEDEC CodeS-PQCC-J
МаркировкаUC2825Q
Width (мм)8.96
Length (мм)8.96
Thickness (мм)4.06
Max Height (мм)4.57
Approx. Price (US$)1.85 | 1ku
Control MethodCurrent
Feedforward
Duty Cycle(Max)(%)80
Frequency(Max)(kHz)1000
Frequency(Min)(kHz)0.1
Gate Drive(Typ)(A)1.5
Operating Temperature Range(C)-40 to 85
Package GroupPLCC
Special FeaturesError Amplifier
Multi-topology
Soft Start
Synchronization Pin
TopologyBoost
Flyback
Forward
Full-Bridge
Half-Bridge
Push-Pull
UVLO Thresholds On/Off(V)9.2/8.4
Vin(Max)(V)30
Vin(Min)(V)9.2
RoHSНе совместим
  • Qualifier TJ = TA Defined
    PDF, 22 Кб, Файл опубликован: 3 ноя 2010
    In the header of most datasheet specification tables there is a qualifier for the tests defined in the table,(TA = TJ, unless otherwise stated). Specifically, these tests are valid for the device as long as the junctiontemperature remains within the specified limits for that device.
  • U-110 1.5 Mhz Current Mode IC Controlled 50-Watt Power Supply
    PDF, 298 Кб, Файл опубликован: 5 сен 1999
    The UC3825 family of PWM control ICs is optimized for high-frequency switched-mode power-supply applications. This application note describes the development of a 1.5 MHz current-mode IC-controlled 50W power supply. Push-pull topology is used for this DC-to-DC converter application of +48V input to +5V at 10A output. Increases in switching speed and dynamic performance are made possible by the U
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UC2825QTR
