Datasheet Texas Instruments TLV1570CPWRG4 — Даташит
СерияTLV1570
МодельTLV1570CPWRG4
10-разрядный, 1,25 MSPS, 8-канальный АЦП, DSP/(Q)SPI IF, Pgmable Int.
2.7 V To 5.5 V 8-Channel 10-Bit 1.25-MSPS Serial Analog-to-Digital Converter datasheet
PDF, 1.0 Мб, Версия: B, Файл опубликован: 13 окт 2000
IC ADC 10BIT SAR 20TSSOP. 10 Bit Analog to Digital Converter 8 Input 1 SAR 20-TSSOP. Data Acquisition - Analog to...
TLV1570CPWRG4
181 ₽
TLV1570CPWRG4
292 ₽
TLV1570CPWRG4
TLV1570CPWRG4
Ref., автоматический или программный PowerDown, очень низкая мощность 20-TSSOP от 0 до 70
Pin20
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаTV1570
Width (мм)4.4
Length (мм)6.5
Thickness (мм)1
Max Height (мм)1.2
# Input Channels8
Analog Voltage AVDD(Max)5.5 В
Analog Voltage AVDD(Min)2.7 В
АрхитектураSAR
Digital Supply(Max)5.5 В
Digital Supply(Min)2.7 В
INL(Max)1 +/-LSB
Input Range(Max)5.5 В
Тип входаSingle-Ended
Integrated FeaturesN/A
InterfaceSPI
Package GroupTSSOP
Power Consumption(Typ)8 mW
Reference ModeExt,Int
Разрешение10 Bits
SINAD60 дБ
SNR61 дБ
Sample Rate (max)1.25MSPS SPS
Sample Rate(Max)1.25 MSPS
THD(Typ)-72 дБ
  • Using the TMS320C5402 DMA Channels to Read from the TLV1570 ADC
    PDF, 423 Кб, Файл опубликован: 22 июн 2000
    This application report presents hardware and software solutions for using the DMA channels of the 16-bit, fixed-point TMS320C5402 DSP to collect digital samples from the TLV1570 10-bit, 1.25-MSPS, 8-channel, serial analog-to-digital converter.
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
На английском языке: Datasheet Texas Instruments TLV1570CPWRG4
